I’m new to HAProxy and am trying find some assistance with a configuration problem. I need to create a configuration that will allow me to dynamically proxy a Tomcat application Context path to a subdomain. The subdomain/path can not be hard coded and should be set up as a variable. I’ve had a look at the other suggestions throughout the site but none of them cover this particular issue. So far, I’ve put together this configuration from various existing examples.
This is what I need.
User request -> http://site1.domain.com/path
Redirect to https
HAProxy then makes a request to its backend pool using the URL http://<ip>:8080/site1/path
When the tomcat application returns links to assets they will have a path that will need to be redirected as well.
Site returns https://site1.example.com/site1/image.jpg
If exists, remove the first site1 from the path. https://site1.example.com/image.jpg
I’ve gotten this far using examples and other guides from this site, but i’m at the limits of knowledge in this area. I’m not sure how to remove the site1 in the path. Any suggestions would be welcome.
# Frontend Definition
frontend tomcat_contexts
bind *:443 ssl crt /etc/haproxy/cert.pem
acl http ssl_fc,not
http-request redirect scheme https if http
default_backend cluster
# Backend Definition
backend cluster
# Perform Subdomain url rewrite
http-request set-var(req.subdomain) req.hdr(host),lower,regsub(\.example\.com$,) if { hdr_end(host) -i .domain.com }
http-request set-path /%[var(req.subdomain)]%[path] if { var(req.subdomain) -m found }
http-request set-header Host example.com if { var(req.subdomain) -m found }
# Cluster machines
server app01 192.168.69.181:8080 check cookie app01
server app02 192.168.69.182:8080 check cookie app02
