If anyone wants to try out 1.8-dev2 dns resolvers, I have setup a docker demo:
You would probably need to reconfigure the hard coded IP addresses. Will get around to making it env based soon.
Asking @willy to release 1.8-dev3, so that all those changes can be easier tested in the field.
Asking myself the same question.
From the Docker Docs:
To bypass the routing mesh, you can start a service using DNS Round Robin (DNSRR) mode, by setting the
--endpoint-mode flagtodnsrr. You must run your own load balancer in front of the service. A DNS query for the service name on the Docker host returns a list of IP addresses for the nodes running the service. Configure your load balancer to consume this list and balance the traffic across the nodes.
How do I actually do that with HAProxy?
Well, either you set multiple server line with the same name:
backend myapp
[ā¦]
server s1 myapp.domain.com:80 check resolvers mydns
server s2 myapp.domain.com:80 check resolvers mydns
server s3 myapp.domain.com:80 check resolvers mydns
Or you use server-template directive:
backend myapp
[ā¦]
server s 3 myapp.domain.com:80 check resolvers mydns
Adjust the number of servers to your need.
In each case, the resolvers should turn on one server per IP found in the response.
Baptiste, I tried to use multiple servers but the requests are not balanced evenly between the servers.
I built an example using Docker and docker-compose. The backend servers count each request they receive and print the number of requests received after 60 seconds.
Code:
The output is
api_4 | f8e1414ea551 0
api_1 | 860eb040651c 0
api_2 | 6af96d901ea8 179
api_5 | 1f15abd0d461 60
api_3 | 271ae04ff5cc 60
One API server receives 180 requests, two receive 60 each and another two receive 0.
Is it possible to round robin to servers which were resolved with DNS?
Did you start 5 instances of āapiā service?
Yes. Five instances of the API service using.
docker-compose up --scale api=5
Youāre missing the āresolvers dockerā statement on your server-template line.
With this enabled, I have the following result:
Starting debug_api_1 ā¦
Starting debug_api_1 ⦠done
Starting debug_api_2 ⦠done
Starting debug_api_3 ⦠done
Starting debug_api_4 ⦠done
Starting debug_api_5 ⦠done
Attaching to debug_haproxy_1, debug_api_1, debug_api_2, debug_api_3, debug_api_4, debug_api_5
api_3 | cd51492adab9 63
api_4 | f5532b40ea80 61
debug_api_3 exited with code 0
debug_api_4 exited with code 0
api_2 | a81602129221 61
api_1 | f8202d903d1b 61
debug_api_2 exited with code 0
debug_api_1 exited with code 0
api_5 | 02f56990bbd4 62
debug_api_5 exited with code 0
You are correct @Baptiste. Apologies!
Thank you so much @z0mb1ek and @baptiste for explaining this I never would have guessed I need multiple server lines!
Iāve spent all weekend trying to figure out why haproxy wouldnāt load balance my docker service even though simple curls show it cycling among the different ipās that my service name resolves to.
In my case I donāt know how large my service will be scaled. How do I know how many duplicate service lines to use? Is there any downside to using whatever maximum I expect?
What is the upcoming better way to do this is there a github issue I can follow or blog post explaining it?
Iāve right now implementing something similar on our infrastructure.
In our case, we have it pointing at an AWS ALB. Since those IPs can change, we donāt want it to hold onto that IP forever.
The final configuration looks something like this:
resolvers default
parse-resolv-conf
timeout resolve 1m
backend be_gw
http-request set-header host aws-gw.contoso.com
option httpchk GET /srv/status HTTP/1.1
http-check send hdr "host" "aws-gw.contoso.com"
default-server init-addr none resolvers default check downinter 2s fastinter 2s inter 3m ssl ca-file /usr/local/etc/haproxy/ca-certificates.crt
server-template gw4- 1-3 aws-gw.contoso.com:443 backup resolve-prefer ipv4
server-template gw6- 1-3 aws-gw.contoso.com:443 resolve-prefer ipv6
Hereās the options applied to these servers and why:
init-addr none: the server starts off blank and then gets populated by the DNS lookupresolvers default: use the ādefaultā resolver group defined at the top of the filessl ca-file ā¦: use TLS and validate with the specified CA fileresolve-opts prevent-dup-ip: one IP per serverbackup: only use IPv4 as backup; this is the year of BOTH the Linux desktop and IPv6resolve-prefer ipv[46]: use these addresses for these serversThe combination of these options gives us the following internal configuration:
'show servers state be_gw' | socat STDIO UNIX-CONNECT:/tmp/haproxy.sock
1
# be_id be_name srv_id srv_name srv_addr srv_op_state srv_admin_state srv_uweight srv_iweight srv_time_since_last_change srv_check_status srv_check_result srv_check_health srv_check_state srv_agent_state bk_f_forced_id srv_f_forced_id srv_fqdn srv_port srvrecord srv_use_ssl srv_check_port srv_check_addr srv_agent_addr srv_agent_port
5 be_gw 1 gw4-1 192.0.2.53 2 0 1 1 5 1 0 0 0 0 0 0 aws-gw.contoso.com 443 - 1 0 - - 0
5 be_gw 2 gw4-2 198.51.100.42 2 0 1 1 5 1 0 0 0 0 0 0 aws-gw.contoso.com 443 - 1 0 - - 0
5 be_gw 3 gw4-3 203.0.113.60 2 0 1 1 5 1 0 0 0 0 0 0 aws-gw.contoso.com 443 - 1 0 - - 0
5 be_gw 4 gw6-1 2001:db8:0:1:bf56:d653:4d5f:5254 2 0 1 1 5 1 0 0 0 0 0 0 aws-gw.contoso.com 443 - 1 0 - - 0
5 be_gw 5 gw6-2 2001:db8:0:2:37ce:beb1:dbd1:78a6 2 0 1 1 5 1 0 0 0 0 0 0 aws-gw.contoso.com 443 - 1 0 - - 0
5 be_gw 6 gw6-3 2001:db8:0:3:92b5:98b9:a514:9f8e 2 0 1 1 5 1 0 0 0 0 0 0 aws-gw.contoso.com 443 - 1 0 - - 0
Note that weāre using two separate sections for IPv4 and IPv6 addresses - this is due to resolve-prefer (default: ipv6) causing only IPv6 addresses to be used (tested on 2.5.7)
