I have HA-Proxy version 1.5.18 2016/05/10
which does TSL termination and then proxies uncrypted configuration to a backend which is an Apache web server.
Everything worked fine unless I tried to use virtual host on Apache side. In setting of virtual host I have set different DocumentRoot than is default, it is /var/www/html/subdirectory.
When I try to ask my browser for url backendserver.com (it is just example of course), I am always proxied to the right backend server, but Apache provides me content of default DocumentRoot /var/www/html.
I would say that the problem is somewhere related to SNI. Apache don’t get the SNI and due to that uses default configuration instead configuration of virtual host. But I am not sure why.
I know that I do TSL termination on HAProxy side. And SNI is an part of SSL handshake, Does it mean that I have to add some header contains SNI into my request?
My backend configuration:
backend backend_server
option httpchk HEAD /subdirectory/
http-request add-header X-Forwarded-For %[src]
server backendserver backendserver.com:443 check rise 60s inter 1000 ssl verify none
Thanks a lot for any advice in advance.
