Understanding HAProxy map_reg Backend Matching Order and Default Route Behavior
I don’t understand how the matching order works with map_reg and base
use_backend %[base,map_reg(/usr/local/etc/haproxy/backend.map)]
This always matches backend-site
example\.com\/shop backend-shop
example\.com\/blog backend-blog
example\.com backend-site
This too
The only solution I’ve found is
example\.com(?!\/(?:shop|blog)) backend-site
But this looks really tricky.
Am I doing something wrong? Is there a correct way to do this?
This should normally do (ordered from most precise to general regexp), which version are you using?
