I want to try HAproxy to forward incoming rtmp to LXD containers. Most all tutorials and examples are
for load balancing. I am not trying to do load balancing.
So say I have an Ubuntu server with HAproxy installed.
I also have a couple of containers on the same server. I want to be able to
forward the incoming rtmp to a specific container.
The incoming rtmp would come from OBS for instance using this format: rtmp://“server IP”:1935/Container1
or Container2, etc.
On the server end, HAproxy would route the incoming rtmp to Container1. This is not exactly load balancing.
You can consider each container is owned by a specific user for the purpose of live streaming.
Any recommendations how to configure HAproxy to handle this?
Thanks Arash. That fixed starting HAproxy. However I am getting an error when when I send rtmp to the server. Here is the config file:
ray@LPC-HAproxy:/etc/haproxy$ cat haproxy.cfg
#use_backend LPC2-backend if url_LPC2
#use_backend LPC3-backend if url_LPC3
#use_backend LPC4-backend if url_LPC4
default_backend LPC1-backend
server 10.28.172.115:1935 check
server 10.28.172.116:1935 check
Here is the haproxy restart:
Jun 24 10:41:37 LPC-HAproxy haproxy[6239]: [WARNING] 174/103720 (6239) : Exiting Master process…
Jun 24 10:41:37 LPC-HAproxy haproxy[6239]: [ALERT] 174/103720 (6239) : Current worker 6243 exited with code 143
Jun 24 10:41:37 LPC-HAproxy haproxy[6239]: [WARNING] 174/103720 (6239) : All workers exited. Exiting… (143)
Jun 24 10:41:38 LPC-HAproxy haproxy[6271]: Proxy rtmp-in started.
Jun 24 10:41:38 LPC-HAproxy haproxy[6271]: Proxy LPC1-backend started.
Jun 24 10:41:38 LPC-HAproxy haproxy[6271]: Proxy LPC2-backend started.
And when I send rtmp, here is the failure:
Jun 24 10:31:31 LPC-HAproxy haproxy[6153]: 192.168.0.5:54741 [24/Jun/2018:10:31:31.844] rtmp-in rtmp-in/ -1/-1/-1/-1/0 400 188 - - PR-- 1/1/0/0/0 0/0 “”
