I’m testing this to load balance a web applications however the developers are telling me that I cannot have vary: Accept-Encoding over the headers, if I use the web application directly on it’s web server indeed I don’t have that header but passing through HAProxy I get that.
Haproxy will set the Vary: Accept-Encoding header, if it compresses the response, which is required to avoid messing up intermediate downstream caching proxies:
Built without PCRE or PCRE2 support (using libc’s regex instead)
h2 : mode=HTTP side=FE mux=H2
: mode=HTX side=FE|BE mux=H1
: mode=TCP|HTTP side=FE|BE mux=PASS
I see something about the use of zlib however in my configuration I don’t have any reference to compression actually I left it very simple just to see if the header would get disabled but it didn’t here’s my config.
log 127.0.0.1 local2
log 127.0.0.1 local2 notice
maxconn 2000
In this configuration, haproxy will not add a Vary header. Make sure that there are no obsolete haproxy processes running in the background (with old configuration), this often happens as haproxy uses SO_REUSPORT, allowing the kernel to bind multiple processes to the same listening socket.
If you can guarantee that the only haproxy instance is running this specific configuration, I suggest you run curl -vv <affected-destination-URL> against haproxy and for comparison, against the backend directly. Provide the output of both and put it into code tags </> here.
