Could someone please explain what scur mean for backend.
I am generating constant load with 100 connections using wrk. For frontend this metric correctly comes to be 100, but for backend, it occasionally comes to be 1 and then 0 for whole duration.
While checking at the server (using ss command), I see constant 100 connections being made from HAProxy instance to this server. My understanding was that this metric gives the current number of active connections to the server (which should have been 100). But since it is giving 0 for whole duration of load generation, I am getting confused.
Load generation:
wrk -c 100 -t5 -d1m -R1000 http://VIP
Config
#maxconn 65536defaults
http-reuse safe
no log
errorfile 504 /etc/haproxy/errors/504.httpfrontend test
bind :80
maxconn 65536
default_backend nginxbackend nginx
server 10.30.10.110 10.30.10.110:81 weight 255
I am using HAProxy 2.0.14 for the test. Also, is “connect” metric the only way to get the actual number of connections being made to the backend?
