szmip
September 13, 2023, 1:01pm
1
What is the recommended configuration for using CA certificates with Certificate chain?
We tried to use single pem file with both CA and root certificates and used ca-file configuration param:
ca-file /mnt/certificates/ca.pem
and also both ca-verify-file and ca-file configuration param like:
ca-file /mnt/certificates/ca.pem ca-verify-file /mnt/certificates/ca-root.pem
but in both cases root is not loaded. Could someone suggest the correct configuration?
MaEh86
September 14, 2023, 6:45am
2
for me, it isn’t 100% clear, what you are trying to do.
Do you want to check client-certificates, add root-certificates for https-backends or secure your frontends with corresponding ssl-certificates?
best regards,
Markus
szmip
September 14, 2023, 7:07am
3
We would like to secure frontends with corresponding ssl-certificates.
Regards,
Paweł
MaEh86
September 14, 2023, 7:40am
4
Then, ca-file is the wrong location
You should have a look here => crt
Example from my config:
frontend haproxy-prod-frontend-https
bind *:443 ssl crt /etc/haproxy/ssl/ alpn h2,http/1.1
best regards,
Markus
