I want to print some fields in LUA script and then add some logic.
How and where do I get the LUA script prints.
Please suggest correct steps for LUA prints.
I have /var/log/haproxy.log enabled but no LUA script print goes to haproxy.log neither any LUA print over console.
Access HAProxy to connect with one of servers
curl -vk --key client1.key --cert ./client1.crt https://2.0.0.2/whoami.html
HAProxy IP = 2.0.0.2
HAProxy config
pidfile /var/run/haproxy.pid
maxconn 4000
lua-load /usr/sbin/lua-choose-backend.lua
frontend http-in
bind *:443 ssl crt /etc/haproxy/server.pem ca-file /etc/haproxy/ca.crt verify required
use_backend %[lua.choose_backend]
default_backend app
reqadd X-Forwarded-Proto:\ https if { ssl_fc }
backend bk1-gr1
server app1 1.0.0.1:80 check
backend bk2-gr1
server app2 1.0.0.2:80 check
backend bk3-gr2
server app3 1.0.0.3:80 check
backend bk4-gr2
server app4 1.0.0.4:80 check
backend default
server app5 1.0.0.5:80 check
clien1 => CN=client1:group-gr1
clien2 => CN=client2:group-gr1
function choose_backend(txn)
     io.write(txn.sf.req_fhdr(Host))
    print(txn.sf.req_fhdr(Host))
        -- some logic here to select backend
        return "app"
return "default"
end
core.register_fetches(“choose_backend”, choose_backend)
