Why lua script on the http-response triggered twice?
Greetings!
For some reason I see double output of a lua func in the haproxy log. Imo, this mean the func triggered twice. Is it a normal behaviour ? Is it possible to avoid double func call ?
Haproxy version - 2.4
Configuration:
[haproxy.cfg]
log /dev/log local0 debug
ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:E
CDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
lua-load /etc/haproxy/lua/register.lua
option log-health-checks
frontend stats
bind :11404
stats uri /
stats refresh 10s
frontend a_cluster
bind *:10080
filter spoe engine request-cache config /etc/haproxy/request-cache.conf
http-request wait-for-body time 1s at-least 10k
http-request lua.pre_node_rp_route rp_cluster_nodes
http-response lua.post_rp_route rp_cluster_nodes
default_backend rp_cluster_nodes
option forwardfor header X-Real-IP
option httpchk
http-check send meth GET uri /actuator/rphealth
http-check expect string “{“status”:“UP”}”
balance hdr(“X-Selected-Node”)
server node_01 10.20.0.79:8080 ssl verify none check port 8081 check-ssl verify none inter 5000
server node_02 10.20.0.46:8080 ssl verify none check port 8081 check-ssl verify none inter 5000
server node_03 10.20.0.48:8080 ssl verify none check port 8081 check-ssl verify none inter 5000
backend agent
timeout connect 5s # greater than hello timeout
timeout server 3m # greater than idle timeout
option spop-check
server iye 10.10.0.10:9000 check
[register.lua]
local function post_rp_route(txn, cluster_name)
core.Info(“Headers :” … txn:get_var(“txn.request_cacher.hdrs”))
end
core.register_action(“post_rp_route”, {‘http-res’}, post_rp_route, 1)
[haproxy.log]
May 19 07:53:47 testnginxrp haproxy[120999]: Headers :.x-terminal-id.1234567890.authorization.Basic XXXXXXXXXX=.content-type.application/json.user-agent.PostmanRuntime/7.29.0.accept./.cache-control.no-cache.postman-token$e64c3f99-b923-4397-b473-768ddf714973.host.10.20.0.49:10080.accept-encoding.gzip, deflate, br.content-length.1373
May 19 07:53:47 testnginxrp haproxy[120999]: 10.10.0.10:59850 [19/May/2022:07:53:46.986] rp_cluster rp_cluster_nodes/node_02 4/0/64/51/119 403 440 - - ---- 1/1/0/0/0 0/0 “POST /api/v1/transfer HTTP/1.1”
May 19 07:53:47 testnginxrp haproxy[120999]: [info] 138/075347 (120999) : Headers :.x-terminal-id.1234567890.authorization.Basic XXXXXXXXXX=.content-type.application/json.user-agent.PostmanRuntime/7.29.0.accept./.cache-control.no-cache.postman-token$e64c3f99-b923-4397-b473-768ddf714973.host.10.20.0.49:10080.accept-encoding.gzip, deflate, br.content-length.1373
It is not doubled call. It is some logging specific.
