Backend IP based on frontend IP
I use Haproxy (1.6 on Ubuntu 12.04) as a SSL termination proxy in front of a Varnish server. Varnish listen several IPs, for virtual host purpose. So I want Haproxy to listen all IPs, and pass each request to Varnish with the same IP.
The configuration could be :
frontend www-https1
   bind 1.1.1.1:443 ssl  strict-sni crt /var/ssl/
   default_backend www-backend1
   server www-1 1.1.1.1:80 check
frontend www-https2
   bind 2.2.2.2:443 ssl  strict-sni crt /var/ssl/
   default_backend www-backend2
   server www-1 2.2.2.2:80 check
etc.
But I would prefer a configuration like this :
frontend www-https
   bind :443 ssl  strict-sni crt /var/ssl/pem/
backend www-backend
   server www-1 ${frontend_ip}:80 check
I saw {frontend_ip} in similar topics, but it doesn't seem to work... My global configuration works because if a put an IP instead of {frontend_ip}, it works.
Any idea ?
Thanks,
[quote=“Kal, post:1, topic:647”]
Varnish listen several IPs, for virtual host purpose. So I want Haproxy to listen all IPs, and pass each request to Varnish with the same IP.[/quote]
This will never scale. Why can’t you use the Host Header to tell Varnish which server is meant?
This is not supported. Fix your real problem: which is the Host information has to be communicated at HTTP level, not IP level between Haproxy and Varnish. Then you will have a lot less problems overall.
I have hundreds of sites (and then hundreds of domains) spread over 6 virtual hosts (currently), it would not be very convenient to use host to select backends in Varnish.
Why? The host header seems much more convenient to me for this.
Haproxy will never support this, as backend servers are always hard configured with a 1:1 relationship.
In Varnish, to select a backend with the host header, the configuration look like this :
    if (req.http.host == "domain1.com" || req.http.host == "domain2.com") {
        set req.backend = backend1;
    elsif (req.http.host == "domain3.com" || req.http.host == "domain4.com") {
        set req.backend = backend2;
With hundreds of domains, the configuration will be huge… And the configuration would have to change almost daily to add new domains.
I don’t really understand the problem with using a huge configuration, isn’t the varnish configuration compiled into C? And don’t you need a similar configuration anyway when its IP based?
I assume that the configuration of new domains is automated anyway.
You need specific, per domain configurations, you will either have a huge haproxy or a huge varnish configuration. I suggest you automatize the problem away.
The configuration isn’t automated for new domains because configuring the DNS record for the domain is enough currently.
I will think about using host header but this would change many things in the server infrastructure…
Thank you for your help, lukastribus !
