I am running haproxy -> (192.168.80.90) on pfsense -> (192.168.80.1), In frontend I have checked the “Use “forwardfor” option.” But instead haproxy forwards the 192.168.80.1 address, instead of the clients ip.
Look for frontend FrontEndProxy
Thanks,
# Generated on: 2020-12-31 02:42
maxconn 1000
log /var/run/log local0 info
uid 80
gid 80
nbproc 1
nbthread 1
hard-stop-after 15m
chroot /tmp/haproxy_chroot
listen HAProxyLocalStats
stats admin if TRUE
stats show-legends
timeout client 5000
timeout server 5000
bind 192.168.80.90:443 name 192.168.80.90:443 ssl crt-list /var/etc/haproxy/FrontEndProxy.crt_list
option socket-stats
acl https ssl_fc
timeout client 30000
acl speed var(txn.txnhost) -m str -i speed.manjot.net
acl auth var(txn.txnhost) -m str -i auth.manjot.net
acl jellyfin var(txn.txnhost) -m str -i jellyfin.manjot.net
acl aclcrt_FrontEndProxy var(txn.txnhost) -m reg -i ^speed\.manjot\.net(:([0-9]){1,5})?$
acl aclcrt_FrontEndProxy var(txn.txnhost) -m reg -i ^auth\.manjot\.net(:([0-9]){1,5})?$
acl aclcrt_FrontEndProxy var(txn.txnhost) -m reg -i ^jellyfin\.manjot\.net(:([0-9]){1,5})?$
use_backend Speed_ipvANY if speed aclcrt_FrontEndProxy
use_backend Auth_ipvANY if auth aclcrt_FrontEndProxy
use_backend Jellyfin_ipvANY if jellyfin aclcrt_FrontEndProxy
frontend HTTP-TO-HTTPS
bind 192.168.80.90:80 name 192.168.80.90:80
acl https ssl_fc
http-request redirect scheme https
frontend GMFrontEndProxy
bind 192.168.80.39:443 name 192.168.80.39:443 ssl crt-list /var/etc/haproxy/GMFrontEndProxy.crt_list
acl gm var(txn.txnhost) -m str -i gm.manjot.net
acl aclcrt_GMFrontEndProxy var(txn.txnhost) -m reg -i ^gm\.manjot\.net(:([0-9]){1,5})?$
use_backend GM_ipvANY if gm aclcrt_GMFrontEndProxy
frontend GM-HTTP-TO-HTTPS
bind 192.168.80.39:80 name 192.168.80.39:80
id 100
timeout connect 30000
timeout server 30000
option httpchk OPTIONS /
server speed 192.168.80.74:443 id 101 ssl check-ssl check inter 1000 verify none crt /var/etc/haproxy/server_clientcert_5f5d1c960d78a.pem
backend Auth_ipvANY
id 104
server Auth 192.168.80.73:443 id 105 ssl check-ssl check inter 1000 verify none crt /var/etc/haproxy/server_clientcert_5f5f10b443a8f.pem
id 106
server jellyfin 192.168.80.18:8920 id 107 ssl check-ssl check inter 1000 verify none crt /var/etc/haproxy/server_clientcert_5f8a7e8154947.pem
backend GM_ipvANY
id 102
option httpchk OPTIONS /si/home.do
server GM 192.168.80.38:9001 id 103 check inter 1000
