I have a problem with the HAPORXY configuration.
I have a public IP.
There are two LAMP servers in my network.
I want to be able to access them from the outside through two different domains on ports 80 and 443.
I have configured HAPORXY for this purpose.
It works. I have access to two servers through two different domains.
The problem is that in the Apache logs on LAMP01 and LAMP02 I can see the IP of the HAPROXY server instead of the client’s real IP.
What do I have to change to see the client’s real IP in the logs?
I added an entry to the Apache configuration file:
]RemoteIPHeader X-Forwarded-For
LogFormat "% a% l% u% t \"% r \ "%> s% O \"% {Referer} i \ "\"% {User-Agent} i \ "" combined
LogFormat "% a% l% u% t \"% r \ "%> s% b" common
Then I executed the command:
a2enmod remoteip && systemctl restart apache2
Below is my configuration file for HAPROXY:
root@haproxy01:~# cat /etc/haproxy/haproxy.cfg
timeout client 60s
timeout server 60s
frontend http_in
acl host_server1 hdr(host) -i mojadomena1.pl
acl host_server2 hdr(host) -i mojadomena2.pl
acl host_server3 hdr(host) -i test.mojadomena2.pl
use_backend http_server1 if host_server1
use_backend http_server2 if host_server2
use_backend http_server3 if host_server3
server server1 server1:80
server server2 server2:80
server server3 server3:80
frontend https_in
bind *:443
acl tls req.ssl_hello_type 1
tcp-request content accept if tls
acl host_server1 req.ssl_sni -i mojadomena1.pl
acl host_server2 req.ssl_sni -i mojadomena2.pl
acl host_server3 req.ssl_sni -i test.mojadomena2.pl
use_backend https_server1 if host_server1
use_backend https_server2 if host_server2
use_backend https_server3 if host_server3
option ssl-hello-chk
server server1 server1:443
server server2 server2:443
server server3 server3:443
frontend stats
bind *:8404
stats uri /stats
stats refresh 10s
stats admin if LOCALHOST
stats auth admin:admin123
Please help me
