Forward Client IP
Hi
I have a HAproxy as a Load Balancer with 2 jboss servers as backends. I am trying to forward the client IP to the jboss servers how ever from the jboss logs I see the HaProxy IP. Below is my config:
log 127.0.0.1 local0
maxconn 4000
pidfile /var/run/haproxy.pid
maxconn 8000
option log-separate-errors
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout check 10s
frontend app_preprod
bind 172.0.0.222:443 ssl crt /etc/haproxy/ssl/certs/cert.pem
bind 172.0.0.222:80
acl url_app_partner path_beg /app-1.0.0
use_backend app_insurance_preprod if url_app_partner
reqadd X-Forwarded-Proto:\ https if { ssl_fc }
capture request header Host len 40
capture request header X-Forwarded-For len 50
capture request header Accept-Language len 50
capture request header Referer len 200
capture request header User-Agent len 200
server 172.0.0.134:8080 check
server 172.0.0.135:8080 check
Always provide the haproxy release (output of haproxy -vv).
Nothing wrong with the haproxy configuration. I assume your jboss backend ignores the x-forward-for header and suggest to double-check on that end.
Cool will check the backend.
BTW here is the version
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
This haproxy release should work just fine regarding x-forwarded-for.
My backend looks at client Ip not x-forward-for, is it possible to forward the client IP?
Use mod_remoteip on Tomcat:
http://httpd.apache.org/docs/trunk/mod/mod_remoteip.html
