Can not forward client ip from load balancer
We are sending https request from client through HAProxy to an internal server.
We are sending header information from client, but when after coming through HAProxy , the header information HTTP_X_FORWARDED_FORare lost somewhere.
Please help us how to forward the header informations through HAProxy.
Following is our config:
Configuration:
log 127.0.0.1 local0
log 127.0.0.1 local1 notice
maxconn 4096
stats socket /etc/haproxy/haproxysock level admin
maxconn 4096
contimeout 50000
clitimeout 50000
srvtimeout 50000
errorfile 503 /etc/haproxy/errors/503_error.html
frontend Http
 default_backend http_web_servers
frontend Https
bind *:443
default_backend https_servers
server webserver-001 xx.xx.xx.xx:443 maxconn 200 check port 80
option abortonclose
# option httpclose
option httpchk GET /health_check/65394534523423412345578568 HTTP/1.0
server webserver-001 xx.xx.xx.xx::80 maxconn 200 check port 80
listen admin_page *:33306
stats uri /
stats realm Strictly\ Private
stats auth :
Do you want to SET a HTTP header, or do you want to FORWARD a HTTP header transparently?
You seem to pass TCP port 443 transparently (and therefor encrypted) to your backends, so you cannot set any HTTP headers obviously, because it is encrypted and-to-end between the client and the backend server.
Because you are using mode tcp for https and just forwarding requests, you’ll need to use
server webserver-001 xx:xx:xx:xx:443 check … send-proxy
since you didn’t mention which webserver you are using, but an nginx example is:
server {
listen 443 ssl http2 default_server proxy_protocol;
// while not completely required you should also set:
set_real_ip_from yy:yy:yy:yy; // haproxy address
real_ip_header proxy_protocol;
the two combinations will send the client ip over https when you are forwarding rather than terminating, when terminating you have as much control as you wish over headers modification. https://cbonte.github.io/haproxy-dconv/1.6/configuration.html#5.2-send-proxy
