1 Public IP 2 webservers ports 80/443 how to?
I am trying to setup haproxy with ubuntu 18 but cant figure out how to set everyting up.
I want to use internal 2 servers with 1 public IP, both servers use ports 80 and 443 and have their own subdomain.
Situation
1 Exchange 2016 server exchage.domain.com internal IP 192.168.1.10
1 Ubuntu nextcloud server nextcloud.domain.com internal IP 192.168.1.5
1 ubuntu server with HAProxy installed IP 192.168.1.2
1 Router IP 192.168.1.1
Both servers (exchange and nextcloud) have ssl certs that auto renew from lets encypt and both servers need port 80 and 443 open.
How can i setup HAProxy that trafic for the exchange server and nextcloud server is deliverd to to correct exchange and nextcloud servers ?
i managed to get it working with this
frontend exchange
bind 192.168.1.2:443 name https
default_backend exchange_servers
server exchangesrv.domain.nl 192.168.1.10 check port 443
server nextcloud.domain.nl 192.168.1.5 check port 443
1 problem the exchange server is using the cert from the nextcloud, how can i change it that every server uses its own certificate ?
Now i get a certificate error on my exchange server.
That’s wrong. You configured haproxy to load-balance between 2 different servers.
You need to content switch on port 80 based on the Host header (in HTTP mode) and on port 443 based on the SNI value (in TCP mode), something like:
frontend http
 bind :80
 use_backend exchangesrv_http if { hdr(Host) -i exchangesrv.domain.nl }
 use_backend nextcloud_http if { hdr(Host) -i nextcloud.domain.nl }
 server exchangesrv 192.168.1.10:80
 server nextcloud 192.168.1.5:80
frontend https
 bind :443 name https
 use_backend exchangesrv_https if { req_ssl_sni -i  exchangesrv.domain.nl }
 use_backend nextcloud_https if { req_ssl_sni -i  nextcloud.domain.nl }
 server exchangesrv 192.168.1.10:443
 server nextcloud 192.168.1.5:443
Also make sure the certificates don’t overlap (not wildcard or SANs covering the other hostname), otherwise browser will try to reuse a connection that is pointing to the wrong server.
Also see:
Thank you very much!, the certificate error is fixed, now both servers get the right certificate.
the exchange and nextcloud server get their own certificate from lets encrypt.
Only one small problem left, my outlook clients keep asking me for a password, it works a few seconds then disconnects.
On my iphone mail from exchange works with no problems, also owa/webmail works good, its the office outlook that keeps asking for password.
do you know what that could be ?
here is part of my logs, i am unsure if there is anything wrong in it.
Sep 1 16:33:34 haproxy haproxy[1161]: 192.168.1.1:55289 [01/Sep/2019:16:33:34.382] http http/ -1/-1/-1/-1/0 503 213 - - SC-- 5/1/0/0/0 0/0 “GET /autodiscover/autodiscover.xml HTTP/1.1”
Sep 1 16:33:34 haproxy haproxy[1161]: 192.168.1.1:55290 [01/Sep/2019:16:33:34.388] http http/ -1/-1/-1/-1/0 503 213 - - SC-- 5/1/0/0/0 0/0 “GET /autodiscover/autodiscover.xml HTTP/1.1”
Sep 1 16:33:42 haproxy haproxy[1161]: 192.168.1.1:55292 [01/Sep/2019:16:33:42.892] https https/ -1/-1/0 0 SC 6/6/0/0/0 0/0
Sep 1 16:33:42 haproxy haproxy[1161]: 192.168.1.1:55293 [01/Sep/2019:16:33:42.892] https https/ -1/-1/0 0 SC 5/5/0/0/0 0/0
Sep 1 16:33:51 haproxy haproxy[1161]: 192.168.1.1:55079 [01/Sep/2019:16:29:29.670] https remote_https/remote 1/0/261770 28368 CD 4/4/3/3/0 0/0
Sep 1 16:33:51 haproxy haproxy[1161]: 192.168.1.1:55094 [01/Sep/2019:16:29:30.910] https remote_https/remote 1/0/260588 2368 CD 3/3/2/2/0 0/0
Is there anyone who has this working?
i have been reading for hours but i cant find a solution, only one but that was mac related, i also tried that with no luck.
the moment i forward port 443 back to the exchange server it works perfect again, so i think its a config somewhere in Haproxy, but where?
This means haproxy cannot reach the exchange server on port 80.
Please provide the output of:
curl -v "http://192.168.1.10:80/autodiscover/autodiscover.xml"
from the haproxy instance. You may have a firewall issue or something like that, not allowing HTTP traffic towards this. Or maybe you just need to configure the client to use HTTPS instead.
edit: you can try redirecting to HTTPS if your exchange instance doesn’t provide HTTP, remove:
and add (only in the http frontend):
redirect scheme https if { hdr(Host) -i exchangesrv.domain.nl }
Output from curl -v “http://192.168.1.10:80/autodiscover/autodiscover.xml”
admin@haproxy:~$ curl -v http://192.168.1.10:80/autodiscover/autodiscover.xml
  • Trying 192.168.1.10…
  • TCP_NODELAY set
  • Connected to 192.168.1.10 (192.168.1.10) port 80 (#0)
Host: 192.168.1.10
User-Agent: curl/7.58.0
Accept: /
< HTTP/1.1 401 Unauthorized
< Server: Microsoft-IIS/10.0
< request-id: 0e8aa857-5983-462c-b20b-185f3b61909c
< X-SOAP-Enabled: True
< X-WSSecurity-Enabled: True
< X-WSSecurity-For: None
< X-OAuth-Enabled: True
< WWW-Authenticate: Basic realm=“192.168.1.10”
< WWW-Authenticate: Negotiate
< WWW-Authenticate: NTLM
< X-Powered-By: ASP.NET
< X-FEServer: SRV1
< Date: Mon, 02 Sep 2019 18:29:59 GMT
< Content-Length: 0
  • Connection #0 to host 192.168.1.10 left intact
I tried changing the redirecting to HTTPS like you suggested but also no result, the moment i start outlook it works for 5 seconds, then it keeps requesting for a password.
Once i switch back the open port 443 to IP 192.168.1.10 it works again.
i am still trying to disable my firewall but that isnt so easy on a USG Ubiquity is see
curl works, so either haproxy itself is misconfigured, or your local OS has some kind of firewall.
Unless that firewall is between haproxy and your exchange server, its should be irrelevant.
I am lost, tried everything, even reinstalled HAPProxy on a fresh ubuntu server, cant really do anything wrong with the installation.
Disabled the local firewall from the windows exchange 2016 server
Changed IP from the HAProxy.
Outlook 2016 keeps asking for a password, strange thing is that it is a login screen from 365 and not my own server.
i use EOP so my MX record is forwarded to 0 mydomain-nl.mail.protection.outlook.com.
    log /dev/log    local0
    log /dev/log    local1 notice
    ssl-default-bind-ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA$
    log     global
    mode    http
    option  httplog
    option  dontlognull
    timeout client  50000
    timeout server  50000
frontend http
bind :80
stats hide-version
stats refresh 30s
stats show-node
stats auth admin:password
stats uri /haproxy?stats
redirect scheme https if { hdr(Host) -i remote.domein.nl }
use_backend cloud_http if { hdr(Host) -i cloud.domein.nl }
backend remote_http
server remote 192.168.1.10:80
backend cloud_http
server cloud 192.168.1.5:80
frontend https
use_backend remote_https if { req_ssl_sni -i remote.domain.nl }
use_backend cloud_https if { req_ssl_sni -i cloud.domein.nl }
server remote 192.168.1.10:443
backend cloud_https
server cloud 192.168.1.5:443
Update,
Moving from Hyper-V to VMware solved the problem.
i also had to put autodiscover in the config no idea why, but it works perfect now.
