you can use the below config in haproxy.cfg file:
log 127.0.0.1 local0 debug
stats socket /var/lib/haproxy/stats mode 660 level admin
ssl-server-verify none
crt-base /etc/pki/tls/certs
ca-base /etc/pki/tls/certs
Default ciphers to use on SSL-enabled listening sockets.
For more information, see ciphers(1SSL). This list is from:
option prefer-last-server
no option httpclose
no option http-server-close
no option forceclose
no option http-tunnel
default-server inter 3s rise 2 fall 3
timeout client 600s
timeout http-request 10s
timeout connect 4s
timeout server 60s
frontend ft_exchange_https
bind 10.1.1.22:80 name http
bind 10.1.1.22:443 name https ssl crt /etc/pki/tls/certs/remote.domain.com.pem crt /etc/pki/tls/certs/pbx.domain.com.pem
capture response header Content-Length len 10
log-format %ci:%cp\ [%t]\ %ft\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %hr\ %hs\ {%sslv/%sslc/%[ssl_fc_sni]/%[ssl_fc_session_id]}\ “%[capture.req.method]\ %[capture.req.hdr(0)]%[capture.req.uri]\ HTTP/1.1”
option socket-stats
stats uri /haproxy?stats
stats realm Strictly\ Private
stats auth YOURSTATLOGINUSER:YOURSTATLOGINPASSWORD
maxconn 1000
#tcp-request content accept if { ssl_fc_has_crt }
acl ssl_connection ssl_fc
acl host_mail hdr(Host) -i remote.domain.com
acl host_assets hdr(Host) -i assets.domain.com
acl host_nc hdr(Host) -i nc.domain.com
acl host_oc hdr(Host) -i oc.domain.com
acl host_pbx hdr(Host) -i pbx.domain.com
acl path_slash path /
acl path_autodiscover path_beg -i /Autodiscover/Autodiscover.xml
acl path_activesync path_beg -i /Microsoft-Server-ActiveSync
acl path_ews path_beg -i /ews/
acl path_owa path_beg -i /owa/
acl path_oa path_beg -i /rpc/rpcproxy.dll
acl path_ecp path_beg -i /ecp/
acl path_oab path_beg -i /oab/
acl path_mapi path_beg -i /mapi/
acl path_check path_end -i HealthCheck.htm
http-request deny if path_check
http-request redirect scheme https code 302 unless ssl_connection
http-request redirect location /owa/ code 302 if path_slash host_mail
use_backend bk_exchange_https_autodiscover if path_autodiscover
use_backend bk_exchange_https_activesync if path_activesync
use_backend bk_exchange_https_ews if path_ews
use_backend bk_exchange_https_owa if path_owa
use_backend bk_exchange_https_oa if path_oa
use_backend bk_exchange_https_ecp if path_ecp
use_backend bk_exchange_https_oab if path_oab
use_backend bk_exchange_https_mapi if path_mapi
use_backend bk_assets if host_assets
use_backend bk_nc if host_oc
use_backend bk_nc if host_nc
use_backend bk_pbx if host_pbx
default_backend bk_exchange_https_default
option httpchk GET /Microsoft-Server-ActiveSync/HealthCheck.htm
http-check expect string 200\ OK
server mail1 10.1.1.5:443 ssl verify none maxconn 1000 weight 10 check
option httpchk GET /Autodiscover/HealthCheck.htm
option httpchk GET /ECP/HealthCheck.htm
option httpchk GET /EWS/HealthCheck.htm
option httpchk GET /mapi/HealthCheck.htm
timeout server 600s
option httpchk GET /OAB/HealthCheck.htm
option httpchk GET /RPC/HealthCheck.htm
timeout server 600s
option httpchk GET /owa/HealthCheck.htm
timeout server 60s
#frontend ft_exchange_smtp
bind 10.1.1.22:25 name smtp
maxconn 10000
default_backend bk_exchange_smtp
#backend bk_exchange_smtp
server mail1 10.1.1.5:25 maxconn 10000 weight 10 check
#frontend ft_exchange_smtps
bind 10.1.1.22:587 name smtps
maxconn 10000
default_backend bk_exchange_smtps
#backend bk_exchange_smtps
server mail1 10.1.1.5:587 maxconn 10000 weight 10 check
#frontend ft_exchange_imaps
bind 10.1.1.22:993 name imaps
maxconn 10000
default_backend bk_exchange_imaps
#backend bk_exchange_imaps
stick store-request src
stick-table type ip size 200k expire 30m
server mail1 10.1.1.5:993 maxconn 10000 weight 10 check
backend bk_assets
option httpclose
server asset1 10.1.1.32:80 maxconn 1000 weight 10 check
backend bk_pbx
option httpclose
server pbx1 10.1.1.30:80 maxconn 1000 weight 10 check
backend bk_nc
option httpclose
server nc1 10.1.1.21:80 maxconn 1000 weight 10 check
