@joel-l please file a bug on github:
Thanks, created: https://github.com/haproxy/haproxy/issues/411
I am finally able to get back to testing the latest release. I am still experiencing significant CPU usage on the new 2.0.17 release compared to 1.6.14.
On 2.0.17, CPU usage for the two threads is around 75% each:
150433 haproxy 20 0 1709760 968884 247944 R 75.8 1.5 7:17.47 haproxy
150434 haproxy 20 0 1709760 968884 247944 S 75.8 1.5 7:12.24 haproxy
On 1.6.14, CPU usage for the two procs is under 35% each:
154476 haproxy 20 0 519152 15292 2744 R 34.8 0.0 0:22.73 haproxy
154496 haproxy 20 0 517880 50340 37792 S 32.8 0.1 0:21.51 haproxy
There is something extremely inefficient with the newer branch.
I attempted to use the simplified config for 2.0 that only uses 2 processes, no threading, no health checks. Still extremely high CPU usage compared to 1.6 which has health checks and what not.
~75% CPU usage on 2.0.17.
159708 haproxy 20 0 173140 90180 3196 S 75.4 0.1 0:58.53 haproxy-2.0
159709 haproxy 20 0 174020 90236 3184 S 74.4 0.1 0:57.72 haproxy-2.0
The results of the ss command are below:
1995 ESTAB
10 LISTEN
Could you test 2.2.2 ? I believe there are substantial improvements in 2.2.
There does not appear to be a repository for haproxy 2.2 for Ubuntu 16. I am not sure when I will have time to setup a build environment.
Hello lukastribus,
I was able to take some personal time to compile 2.2.2. Unfortunately I did not see any improvements. It still used about the same amount of CPU as 2.0.17.
I did not compile in LUA or PCRE since they both wanted some more development tools involved and I do not use them in this basic config. I would hope that this would not cause a problem.
/usr/sbin/haproxy-2.2 -vv
HA-Proxy version 2.2.2 2020/07/31 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.2.2.html
Running on: Linux 4.4.0-141-generic #167-Ubuntu SMP Wed Dec 5 10:40:15 UTC 2018 x86_64
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_OPENSSL=1 USE_ZLIB=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with multi-threading support (MAX_THREADS=64, default=40).
Built with OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Running on OpenSSL version : OpenSSL 1.0.2g 1 Mar 2016
Built without PCRE or PCRE2 support (using libc’s regex instead)
Built with gcc compiler version 5.4.0 20160609
: mode=HTTP side=FE|BE mux=H1
Available services : none
[FCGI] fcgi-app
Also, I tried a second build of 2.2.2 with DEFINE="-DMAX_READ_POLL_LOOPS=1" and this did not help either.
It’s difficult for me to do a controlled test, but I ran a few more. There appear to be some gains in 2.2, but not enough to offset the losses that exist in 2.0 compared to 1.6.
195572 haproxy 20 0 524540 21072 1988 R 28.5 0.0 0:08.49 haproxy-1.6
195592 haproxy 20 0 525296 37236 17436 S 28.1 0.1 0:08.34 haproxy-1.6
195277 haproxy 20 0 163592 81580 3016 S 56.2 0.1 0:07.23 haproxy-2.0
195276 haproxy 20 0 163920 81848 3056 S 50.0 0.1 0:08.04 haproxy-2.0
195039 haproxy 20 0 159852 75164 3476 R 45.0 0.1 0:18.01 haproxy-2.2
195040 haproxy 20 0 160020 75620 3480 S 45.0 0.1 0:18.71 haproxy-2.2
I’m not sure I can help you myself. Its probably better if you just file a bug at github:
Understood. I opened https://github.com/haproxy/haproxy/issues/822
