2 frontends SSL over HTTP and TCP?
Hello, can i use 2 frontends configured with ssl but one frontend in tcp mode and the other in http mode? In the same port (443)
I try this:
frontend http-in
bind 0.0.0.0:80
bind 0.0.0.0:443 ssl crt /etc/pki/tls/private/cert.pem
option contstats
acl host_host2 hdr(host) -i host2.domain.com
use_backend host2_cluster if host_host2
frontend https-in
bind 0.0.0.0:443
acl host_host1 req.ssl_sni -i host1.domain.com
use_backend host1_cluster if host_host1
I get this error in log (not found the server https://host1.domain.com and not found https://host2.domain.com)
Jun 30 10:04:57 localhost haproxy[4570]: 172.21.6.23:36510 [30/Jun/2017:10:04:57.885] http-in~ http-in/ -1/-1/-1/-1/23 503 212 - - SC-- 6/0/0/0/0 0/0 “GET / HTTP/1.1”
thanks in advance!
No, you cannot bind to “0.0.0.0:443” twice, that will lead either to a bind error on startup or to a nasty kernel-based load-balancing between the two sockets (when REUSEPORT is supported).
You can only have one 0.0.0.0:443 socket, and use TCP mode to SNI route it to different destination; use a dedicatated backend to respin this traffic to the correct (TLS terminating) frontend. Abstract namespace sockets (abns) lend itself to this purpose very well.
So this would look something like this:
backend respin-tls-term
 server loopback-for-tls abns@haproxy-tls-term send-proxy-v2
frontend http-in
 bind 0.0.0.0:80
 bind abns@haproxy-tls-term accept-proxy ssl crt /etc/pki/tls/private/cert.pem
 option contstats
frontend https-in
 bind 0.0.0.0:443
 use_backend respin-tls-term if { req.ssl_sni -i host2.domain.com }
thank you lukastribus.
I have tried this configuration, and https://host1.domain.com works well but https://host2.domain.com gets this error:
Jun 30 10:54:34 localhost haproxy[4616]: 172.21.6.23:36978 [30/Jun/2017:10:54:34.730] https-in respin-tls-term/ -1/-1/0 187 PR 2/0/0/0/3 0/0
Jun 30 10:54:44 localhost haproxy[4616]: 172.21.6.23:36982 [30/Jun/2017:10:54:44.890] https-in respin-tls-term/ -1/-1/0 187 PR 0/0/0/0/3 0/0
Jun 30 10:54:47 localhost haproxy[4616]: 172.21.6.23:36986 [30/Jun/2017:10:54:47.065] https-in respin-tls-term/ -1/-1/0 187 PR 2/2/0/0/3 0/0
thanks in advance
sorry, the log:
Jun 30 11:06:10 localhost haproxy[4616]: 172.21.6.23:37060 [30/Jun/2017:11:06:10.932] https-in respin-tls-term/ -1/-1/0 187 PR 10/10/5/0/3 0/0
Jun 30 11:06:10 localhost haproxy[4616]: 172.21.6.23:37070 [30/Jun/2017:11:06:10.932] https-in respin-tls-term/ -1/-1/0 187 PR 9/9/4/0/3 0/0
Jun 30 11:06:10 localhost haproxy[4616]: 172.21.6.23:37068 [30/Jun/2017:11:06:10.932] https-in respin-tls-term/ -1/-1/0 187 PR 8/8/3/0/3 0/0
Jun 30 11:06:10 localhost haproxy[4616]: 172.21.6.23:37066 [30/Jun/2017:11:06:10.932] https-in respin-tls-term/ -1/-1/0 187 PR 7/7/2/0/3 0/0
Jun 30 11:06:10 localhost haproxy[4616]: 172.21.6.23:37064 [30/Jun/2017:11:06:10.932] https-in respin-tls-term/ -1/-1/0 187 PR 6/6/1/0/3 0/0
Jun 30 11:06:10 localhost haproxy[4616]: 172.21.6.23:37062 [30/Jun/2017:11:06:10.932] https-in respin-tls-term/ -1/-1/0 187 PR 5/5/0/0/3 0/0
Jun 30 11:06:10 localhost haproxy[4616]: 172.21.6.23:37072 [30/Jun/2017:11:06:10.958] https-in respin-tls-term/ -1/-1/0 187 PR 5/5/0/0/3 0/0
What error do you see in the client? 400 or 403?
Not sure what happens here, are you sure you have “send-proxy-v2” in the new backend and “accept-proxy” in the the “bind abns” config line?
ok, i have a problem with copy&paste with this form
In the log i see “NOSRV”
thanks
Can you put it on pastebin.com please?
of course
https://pastebin.com/BJYNWg3K
In chrome i see
This site can’t provide a secure connection
host2.domain.com sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
Probably your kernel doesn’t support abns (although I would expect a bind error).
Try replacing the two “abns@haproxy-tls-term” declarations with 127.0.0.1:1443, so we use a localhost IP socket instead.
same error log
thanks
I need to know the complete configuration.
Try replacing “backend respin-tls-term” with “mode tcp” in “backend respin-tls-term”.
Also, do you see any other syslog messages when starting haproxy, like server down in the respin-tls-term backend?
there are no errors
Jun 30 12:14:56 hglb2 systemd: Starting HAProxy Load Balancer…
Jun 30 12:14:56 localhost haproxy[4784]: Proxy respin-tls-term started.
Jun 30 12:14:56 localhost haproxy[4784]: Proxy http-in started.
Jun 30 12:14:56 localhost haproxy[4784]: Proxy https-in started.
Jun 30 12:14:56 localhost haproxy[4784]: Proxy host1_cluster started.
Jun 30 12:14:56 localhost haproxy[4784]: Proxy host2_cluster started.
Jun 30 12:16:26 localhost haproxy[4785]: 172.21.6.23:38610 [30/Jun/2017:12:15:34.630] https-in respin-tls-term/loopback-for-tls 1/0/52018 2458 sD 9/7/1/1/0 0/0
chrome is waiting https://host2.domain.com and no occurs nothing
the config:
frontend http-in
bind 0.0.0.0:80
option contstats
frontend https-in
bind 0.0.0.0:443
default-server inter 5s fall 2 on-marked-down shutdown-sessions
server node1 192.168.2.1:443 check cookie s1
server node2 192.168.2.2:443 check cookie s2
option log-health-checks
server node1 192.168.1.1:443 check
server node2 192.168.1.2:443 check
and the same replacing
server loopback-for-tls 127.0.0.1:1443 send-proxy-v2
and
bind 127.0.0.1:1443 accept-proxy ssl crt /etc/pki/tls/private/cert.pem
no errors
thanks!
I mean the default and global section of your configuration.
ok
ssl-server-verify none
maxconn 1024
log 127.0.0.1 local0 debug
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
timeout queue 60s
I don’t know what’s wrong, the same configuration works fine for me.
Can you:
  • confirm your browser sends the TLS handshake with a SNI
  • post the output of “haproxy -vv”
  • post the output of “curl -vk https://host2.domain.com/asd
  • run through “strace -tt” when the issue fails (a lot of output, put it on pastebin.com)
