400 bad on https frontend to https backend
Hello, I’m trying to set up a reverse proxy for an application that is running on HTTPS and does not accept http, only https and it cannot be changed. Using Haproxy, the redirection is always thrown to HTTP and not to HTTPS in the backend, causing a bad request 400. I’ve searched the internet and haven’t found a solution. The strange thing is that I can make it work on Squid Proxy.
NOTE: I’m using PFsense as a Proxy
My haproxy.cfg:
maxconn 1000
uid 80
gid 80
nbthread 1
hard-stop-after 15m
chroot /tmp/haproxy_chroot
listen HAProxyLocalStats
stats admin if TRUE
stats show-legends
timeout client 5000
timeout server 5000
frontend FrontEnd_HTTPS
bind 192.168.1.14:443 name 192.168.1.14:443 ssl crt-list /var/etc/haproxy/FrontEnd_HTTPS.crt_list
timeout client 30000
acl acl_zkbio var(txn.txnhost) -m str -i zkbio.teste.com.br
acl aclcrt_FrontEnd_HTTPS var(txn.txnhost) -m reg -i ^zkbio.teste.com.br(:([0-9]){1,5})?$
use_backend Backend_ZKbio_ipvANY if acl_zkbio aclcrt_FrontEnd_HTTPS
id 100
http-check send meth GET ver HTTP/1.1\r\nHost:\ 192.168.200.10:8098\r\nAccept:\ /
timeout connect 30000
timeout server 30000
option httpchk
server zkbio 192.168.200.10:8098 id 101 ssl check inter 1000 verify none
I solved the problem by changing the frontend port from 443 to 8098 and creating a new frontend 443 redirecting requests to frontend 8098 which forwards to the backend https 8098, and it worked.
