Hi everyone,
I’m trying to use haproxy instead of apache2 to setup a reverse proxy in my company.
I followed/compared some documentations to make my own haproxy.cfg
Haproxy is running on its own server, and has to redirect https requests on another web server. As you’ll see in the below configuration (i think) i redirect any http request on https.
The problem is that i get the “BAD REQUEST” error when trying to access my test website. The certificates seems to work because i can see it in my web browser, and i got no error about it in the log, however, in that /var/log/haproxy.log, i can only see that the request seems to be correctly redirected on the backend web server :
Jan 25 16:48:14 haproxyserver haproxy[5570]: 37.169.147.6:37646 [25/Jan/2019:16:48:14.100] localhost-443~ redirect-website1/webserver1:443 75/0/131 619 -- 1/1/0/0/0 0/0
What i’m doing wrong ?
For information, that process worked correctly reverse proxy by apache, but i can’t use it anymore since i have to setup another redirection for another domain, and apache2 can’t handle more than 1 public certificate (or maybe i’m doing something wrong too, but i’m not here for that, anyway haproxy seems to be a more convenient and powerful tool
Find below the configuration file
Thanks in advance for your precious help!
Arnaud
Here is the complete haproxy.cfg, (commented!)
maxconn 4096
timeout connect 15s
timeout client 15s
timeout server 15s
frontend rvsproxyserver-80
redirect scheme https code 301 if !{ ssl_fc } #redirect everything to https
frontend rvsproxyserver-443
bind *:443 ssl crt /var/www/certs/haproxy #concatened .pem certs location for websites
acl tls req.ssl_hello_type 1
tcp-request content accept if tls
acl is_website1 hdr(host) website1 #simple acl1
acl is_website2 hdr(host) website2 #simple acl2
use_backend redirect-website1 if is_website1 #declare backend1
use_backend redirect-website2 if is_website2 #declare backend2
option ssl-hello-chk
server webserver1 10.10.10.10:443 check #name and IP of my webserver1
server webserver2 10.11.11.11:443 check #name and IP of my webserver2
