I have a backend with some really really slow routes, which response can take up to 20 minutes for data extractions.
This is gonna be moved to async actions at some point, but for the moment I’m facing 504 errors.
I tried to play with timeout server and timeout client, and then with a lof of other options without success. With all my attemps, I’m getting a 504 after 60seconds.
Here is my haproxy configuration:
maxconn 50000
ssl-default-bind-ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
ssl-default-server-ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
stats socket /var/run/haproxy/socket
server-state-file global
server-state-base /var/state/haproxy/
lua-load /marathon-lb/getpids.lua
lua-load /marathon-lb/getconfig.lua
backlog 10000
maxconn 10000
timeout connect 3s
timeout client 30s
timeout server 30s
timeout tunnel 3600s
timeout http-keep-alive 1s
timeout http-request 15s
timeout queue 30s
timeout tarpit 60s
bind 0.0.0.0:9090
balance
monitor-uri /_haproxy_health_check
acl getpid path /_haproxy_getpids
http-request use-service lua.getpids if getpid
acl getconfig path /_haproxy_getconfig
http-request use-service lua.getconfig if getconfig
frontend admin_apps_web_10008
bind *:10008
use_backend admin_apps_web_10008
timeout http-keep-alive 3600s
timeout server 3600s
timeout client 3600s
timeout tarpit 3600s
timeout http-request 3600s
clitimeout 3600s
srvtimeout 3600s
option httpchk GET /_health_check
timeout check 10s
server 10_0_1_242_22512 10.0.1.242:22512 weight 1 minconn 1 maxconn 3 check inter 10s rise 1 fall 4
Any idea? Thanks
