Apologies if i’m completely misusing HA Proxy. However, I’ve started to host some websites for friends but down to the lack of public facing IP’s i’ve been trying to use the one IP and then HA proxy decided which backend it should go to.
I’m currently using ACLs with “if this url then point to this backend”. However, looks like it’s sometimes bouncing between whatever backend is available instead of the single one that i’ve specified.
# Configuration for HTTP site
frontend http-in
acl owlmagic hdr(host) owlmagic.mydomain.com
acl JamesT hdr(host) jamest.mydomain.com
use_backend OwlMagic if owlmagic
use_backend JamesTay if JamesT
backend OwlMagic
server WEB1 192.168.10.12:80
backend JamesTay
server WEB2 192.168.10.16:80
However, whenever i access JamesT.mydomain.com it sometimes points to the correct backend and then others it will point to OwlMagic and vice versa.
Is this a config problem on my end or am I not using this correctly at all?
Thanks,
Provide the full configuration you are using, the output of haproxy -vv and the output of the logs in httplog format.
As requested:
log 127.0.0.1 local0 notice
maxconn 50000
timeout client 30s
timeout connect 4s
timeout server 30s
frontend http-in
acl owlmagic hdr(host) owlmagic.adamsitsolutions.co.uk
acl JamesT hdr(host) jamest.adamsitsolutions.co.uk
# acl MonitoringAdamsIT url_beg /monitoring.adamsit
use_backend JamesTaylor if JamesT
#frontend https-in
# bind 192.168.1.114:443
# use_backend Monitoring if MonitoringAdamsIT
backend OwlMagic
#balance roundrobin # Load Balancing algorithm
option httpchk
server WEB1 192.168.10.12:80 weight 1 maxconn 512 check
backend JamesTaylor
AProxy version 2.4.12-1ppa1~focal 2022/01/11 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.4.12.html
Running on: Linux 5.4.0-99-generic #112-Ubuntu SMP Thu Feb 3 13:50:55 UTC 2022 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-b7TO7s/haproxy-2.4.12=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
DEBUG =
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -CLOSEFROM -ZLIB +SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL -PROCCTL +THREAD_DUMP -EVPORTS -OT -QUIC +PROMEX -MEMORY_PROFILING
Built with OpenSSL version : OpenSSL 1.1.1f 31 Mar 2020
Running on OpenSSL version : OpenSSL 1.1.1f 31 Mar 2020
Built with gcc compiler version 9.3.0
h2 : mode=HTTP side=FE|BE mux=H2 flags=HTX|CLEAN_ABRT|HOL_RISK|NO_UPG
[FCGI] fcgi-app
Sorry, where would i be able to locate the logs for httplog ? I cannot locate under /var/logs/
So been playing about with this further and it will connect to the correct back end at times. Then it will 503 then bounce back to the incorrect back end.
So I’m not sure where I’m going wrong here.
Screenshot below for how i want to do this
