Inconsistent ACL resolution resulting in incorrect backend selection
I have a single frontend that I would like to send to two different backends based on the requested url.
Example Frontend Config
frontend example_https
bind 192.168.1.5:443 ssl crt /etc/ssl/private/certname.pem alpn h2,http/1.1
acl is_jim path -i /jim.asmx
use_backend jim_webservers_https if is_jim
default_backend bob_webservers_https
With the config above if I request www.example.com/jim.asmx, my requests are sometimes successful. By looking in the haproxy.logs, I can see that for the failed requests the wrong (default) backend is being selected.
I have tried various different approaches eg using path/path_beg/path_end but always appear to encounter inconsistent behaviour. I tends to either work/not work in a particular browser session until I change it/reopen/change browser. That said this pattern is not consistent, all the while haproxy.log shows the same uri being requested and being routed to different backends.
This would suggest my ACL is not being matched correctly
Any thoughts on what to try?
Can you share the complete configuration, the actual log line and the output of haproxy -vv please.
Thanks for the reply, please find output below
HA-Proxy version 1.8.8-1ubuntu0.3 2019/01/11
  TARGET  = linux2628
  CPU     = generic
  CC      = gcc
  CFLAGS  = -g -O2 -fdebug-prefix-map=/build/haproxy-_XfIfg/haproxy-1.8.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
  OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_NS=1
Built with OpenSSL version : OpenSSL 1.1.0g  2 Nov 2017
Running on OpenSSL version : OpenSSL 1.1.0g  2 Nov 2017
Below is an example of requests from the haproxy log, the same frontend is being used with the same page requested each time
[04/Mar/2019:10:37:13.146] vip7_https~ lead_webservers_https/web03 0/0/1/101/102 200 3466 - - ---- 1/1/0/0/0 0/0 "GET /Leads.asmx HTTP/1.1"
[04/Mar/2019:10:37:18.987] vip7_https~ lead_webservers_https/web04 0/0/0/124/124 200 3466 - - ---- 1/1/0/0/0 0/0 "GET /Leads.asmx HTTP/1.1"
[04/Mar/2019:10:37:20.756] vip7_https~ lead_webservers_https/web03 0/0/1/3/4 200 3466 - - ---- 1/1/0/0/0 0/0 "GET /Leads.asmx HTTP/1.1"
[04/Mar/2019:10:37:30.329] vip7_https~ vip7_webservers_https/web08 0/0/1/2/3 404 2210 - - ---- 1/1/0/0/0 0/0 "GET /Leads.asmx HTTP/1.1"
[04/Mar/2019:10:37:33.742] vip7_https~ vip7_webservers_https/web08 0/0/1/2/3 404 2210 - - ---- 1/1/0/0/0 0/0 "GET /Leads.asmx HTTP/1.1"
[04/Mar/2019:10:37:36.836] vip7_https~ vip7_webservers_https/web09 0/0/0/3/3 404 2210 - - ---- 1/1/0/0/0 0/0 "GET /Leads.asmx HTTP/1.1"
[04/Mar/2019:10:37:37.499] vip7_https~ vip7_webservers_https/web08 0/0/1/2/3 404 2210 - - ---- 1/1/0/0/0 0/0 "GET /Leads.asmx HTTP/1.1"
[04/Mar/2019:10:37:38.143] vip7_https~ vip7_webservers_https/web09 0/0/0/2/2 404 2210 - - ---- 1/1/0/0/0 0/0 "GET /Leads.asmx HTTP/1.1"
Below is the frontend and the non default backend
frontend vip7_https
    bind redacted:443  ssl crt /etc/ssl/private/redacted.pem alpn h2,http/1.1
    acl is_leads path -i /Leads.asmx
    acl is_leads_subdir path -i /LeadServiceMS/Leads.asmx
    use_backend lead_webservers_https if is_leads is_leads_subdir
    default_backend vip7_webservers_https
    http-request set-header X-Forwarded-Proto https if  { ssl_fc }
    acl is_leads_subdir path_sub -i LeadServiceMS
    reqrep ^([^\ :]*)\ /(.*)     \1\ /LeadServiceMS/\2 if !is_leads_subdir
    server      web03 redacted:443 check weight 1 ssl verify none
    server      web04 redacted:443 check weight 1 ssl verify none
Any help is full appreciated.
Did you try swapping order?
Also, try building a new backend for the other instead of relying on default?
I find when I want specific, I need to be obtusely specific. Worth a shot :slight_smile:
The entire configuration is needed. Including global section, default section and especially the vip7_webservers_https backend.
Also double and triple check that you don’t have any obsolete, old haproxy instances running in the background. If you want to be sure, restart haproxy with noreuseport enabled.
Thank you both for your feedback. As it turns out I had loads of old HAproxy instances running in the background. After killing these off my rules were followed correctly.
To avoid these old instances, what are my options?
Is there an appreciable outage when one uses noreuseport?
Below is my global/default config for sockets/expose-fd listeners
    log /dev/log    local0
    log /dev/log    local1 notice
    log     global
    mode    http
    option  httplog
    option  dontlognull
    timeout client  50000
    timeout server  50000
Thanks again for your guidance
There reasons for instances still running in the background can be multiple; most likely reasons are issues and bugs in the process handling.
I’d suggest you upgrade to 1.8.19 first of all. You can do that on Ubuntu by using Vincent Bernat’s PPA:
https://launchpad.net/~vbernat/+archive/ubuntu/haproxy-1.8/
I’m not sure noreuseport really fixes this, it does guarantee though that a restart would fail if the ports are still bound by an old instance.
I’d therefor suggesting to switch to the PPA for the current release and monitor the situation.
Thanks for that, I’ll test this out and give it a go.
Cheers
