Mac
March 15, 2022, 2:19pm
#1
Hello Everyone,
I have an application that requires client certificate authentication. These applications run on different ports and are accessed by path. https://host.domain.com:9443/application1 , https://host.domain.com:9444/application2 .
I would like to ‘hide’ those ports or redirect to the backend for each of those separate application.
Do I terminate the TLS at the HAProxy, use an ACL to determine the correct backend server - than pass the client certificate as a header?
Is that the correct approach?
Mac
March 20, 2022, 8:17pm
#2
Further follow-up to my question. Attached is my config.
So I do certificate authentication to HAProxy and terminate so that I can examine the URL Path.
If it is just a host.domain than pass that through a a Web Site.
If the host.domain includes a path than redirect to that specific application port.
frontend web-in
bind *:443 ssl verify required crt /etc/haproxy/cert/cert.pem ca-file /etc/haproxy/cert/cacert.pem
http-request set-header SSL_CLIENT_CERT &[ssl_c_der.base64]
http-request set-header X-Real-IP %[src]
acl user_app1 path -i -m beg /Application/
use_backend web if { req.hdr(host) -i host.domain.com }
use_backend app1 if user_app1
default_backend web
backend web
server web1 192.1.1.121:443 ssl verify none
backend app1
server app_srv1 192.1.2.121:9443 ssl verify none
