Good Evening,
I want to have a certificate-based authentication configured only on a backend
test5_ssl
in such a way that the configuration would not impact other nodes (test_1_ssl, test_2_ssl, test_3_ssl, test_4_ssl). My question is how to do it?
P.S.
my HAProxy version is 1.5.18
I have a following configuration
frontend primordial_ssl
log 127.0.0.1:514 local0 notice
—>>> LINE of INTEREST bind *:443 ssl crt /etc/ssl/server.pem ca-file /etc/haproxy/ca.crt verify required
http-request set-header X-SSL-Client %{+Q}[ssl_c_der,base64]
acl test_1 hdr_dom(host) -i -f /etc/haproxy/test1
acl test_2 hdr_dom(host) -i -f /etc/haproxy/test2
acl test_3 hdr_dom(host) -i -f /etc/haproxy/test3
use_backend test_1_ssl if test_1
use_backend test_2_ssl if test_2
use_backend test_3_ssl if test_3
default_backend test4backend test_1_ssl
cookie testcookie prefix nocache
option httpchk HEAD / HTTP/1.1.\r\nHost:localhost
http-request set-header X-Forwarded-Host %[req.hdr(Host)]
server test1_s test.com:18443 cookie 01 id 1011 ssl verify none
errorfile 503 /etc/haproxy/maintenance_pages/testmaintenance1.httpbackend test_2_ssl
cookie test2cookie prefix nocache
server test2_s test.com:18443 cookie 01 id 11011 ssl verify none
errorfile 503 /etc/haproxy/maintenance_pages/test2.httpbackend test3_ssl
cookie test3cookie insert indirect nocache
server test3_s test.com:8443 cookie 01 id 4011 ssl verify none
errorfile 503 /etc/haproxy/maintenance_pages/testmaintenance1.httpbackend test4_ssl
cookie test4cookie insert indirect nocache
server test4_s test.com:8443 cookie 01 id 4011 ssl verify none
errorfile 503 /etc/haproxy/maintenance_pages/testmaintenance1.http#—>> HOW to configure this node to accept only certificate based connections
#—>> without any impact on other nodes?
backend test5_ssl
#bind *:443 ssl crt /etc/ssl/server.pem ca-file /etc/haproxy/ca.crt
cookie test5cookie
server test5 test.com:19090 cookie 01 id 1001 check inter 2000 rise 2 fall 5
