Is this possible - HAProxy 2 Way SSL - Cert Auth Reverse Proxy
We have a backend system that communicates over SSL and clients must present a Client Certificate.
We are using HAProxy as a Reverse Proxy to these servers.
Our configuration looks like this -
log /dev/log local2 error
timeout client 5000
timeout server 5000
bind *:8081
stats uri /
stats realm Haproxy\ HAProxy Statistics
stats auth xxxxx:xxxxx
frontend www-https-in
bind *:443 transparent ssl crt /etc/cert/site.pem ca-file /etc/cert/cacert.pem verify required
default_backend app_backend
backend app_backend
stick-table type ip size 200k expire 30m
stick on src
server appserv1 10.10.10.12:8000 ssl crt /etc/cert/site.pem verify none
The Reverse Proxy works and the Client Certificate functions at the Front - but the backend is attempting to validate a SSL Certificate and not the Clients Certificate.
How do I get the Client Certificate to pass through to the appserver?
Don’t terminate SSL at haproxy. Your specific requirement is to have the SSL client cert presented to the backend server, so instead re-encrypting everything and hiding the client cert, let it pass through.
Hi Mac
I have same issue here, did you solve your issue if yes, kindly share it here. thank you
best regards, Fahad
Hi Fahad,
As Lukas said, don’t terminate SSL on HAProxy in such a situation. If you do, HAProxy would need both the certificate and the private key from every user for it to be able to sign in with them. This does not make sense at all and would comrpomise / expose clients’ private keys.
So just don’t terminate SSL on HAProxy and forward it straight to the backend where the server itself will receive and certificate and will handshake the session with the clients.
Hello Mac,
Could you please share your configuration with us, like you did in the first post?
