I’m using HAProxy to load balance between four servers, which requires a user to present a certificate in order to login to. When the user hits the webpage they are asked to present their certificate but the certificate never gets through to the server to authenticate with. I’ve tested logging in without HAProxy in front of it and everything works correctly. I have pasted what my configuration setup looks like.
uid 0
gid 0
maxconn 45000
timeout server 86400000
timeout connect 86400000
timeout client 86400000
timeout queue 1000s
frontend 443_oam
bind 192.168.0.208:443
default_backend oam_443
backend oam_443
option ssl-hello-chk
server oam01 :443 check
server oam02 :443 check
server oam03 :443 check
server oam04 :443 check
