I want to setup haproxy as simple tcp-proxy. Below is my configuration. When I try to send e-mail via Thunderbird(pointing smtp to ip_of_my_host:8123) or simple python script I get an error about not valid certificate or certificate error. I thought Layer 4 doesn’t care about it at all. Isn’t SSL/TLS a L7 feature? So how setup it properly?
frontend smtp
bind *:8123
default_backend smtp-backend
server s1 smtp.gmail.com:465
With SSL Pass-Through, no SSL certificates need to be created or used within HAproxy. The backend servers can handle SSL connections just as they would if there was only one server used in the stack without a load balancer.
So what’s wrong with my configuration? I want end smtp server to handle certificates.
