like here written:
http://www.haproxy.com/blog/emulating-activepassing-application-clustering-with-haproxy/
Tested an all versions of last ~ 6 months from debian Backport… actual this is
# haproxy -v
HA-Proxy version 1.7.5-2~bpo8+1 2017/05/27
My setup:
haproxy are each on same servers/different port as gearmand as frontend:
peers LB
peer gearman-jobserver-euc1-01 172.31.18.242:8999
peer gearman-jobserver-euc1-02 172.31.7.104:8999
backend BE_gearman-jobserver_staging
fullconn 10000
email-alert mailers sendmail
email-alert level alert
email-alert from haproxy@gearman-jobserver-euc1-01.xxx
email-alert to sysops@xxx
timeout client 60s
timeout client-fin 60s
timeout server 60s
timeout tunnel 1h
option tcp-check
stick-table type integer size 1 nopurge peers LB
tcp-check send STATUS\r\n
tcp-check expect string . comment Minimum\ empty\ response.
stick on dst_port
server gearman-jobserver-euc1-01 172.31.18.242:40025 check inter 2s fastinter 1s downinter 20s fall 3 rise 2
server gearman-jobserver-euc1-02 172.31.7.104:40025 check inter 2s fastinter 1s downinter 20s fall 3 rise 2 backup
and the default socket status is fine:
root@gearman-jobserver-euc1-01:~# echo "show table BE_gearman-jobserver_production" | socat unix:/run/haproxy/admin.sock -
# table: BE_gearman-jobserver_production, type: integer, size:1, used:1
0x5565daacc984: key=50005 use=0 exp=0 server_id=1
but the problem is that if server01 is down the stays on “server_id=1” and didn’t switch as expected.to server_id=2.
Do I missed some requirements which weren’t written in blog / I cannot find in documentation or is this a bug ?
Thanks and Bests
Reiner
