I am attempting to do an haproxy setup with one frontend VIP and two backend web servers. I want the backend to be active/passive so that all requests go to server #1 unless server #1 is down, then send to server #2. When server #1 comes alive, stay on server #2 until server #2 fails.
I followed the guide below using stick tables to implement and it was working but now it seems to have stopped and I don’t know why. When I fail a server, it correctly sends to the backup but when the failed server comes back online, it is sending the traffic to the newly fixed server instead of staying on the backup.
I am running HAProxy 1.8.17. Here is a sanitized copy of the haproxy.cfg. Any ideas??
# Global settings
    # need to:
    # 1) configure syslog to accept network log events.  This is done
    #    by adding the '-r' option to the SYSLOGD_OPTIONS in
    #    /etc/sysconfig/syslog
    #   file. A line like the following can be added to
    #    local2.*                       /var/log/haproxy.log
    log         127.0.0.1 local2
    chroot      /var/lib/haproxy
    maxconn     4000
    user        haproxy
    group       haproxy
    # turn on stats unix socket
    stats socket /var/lib/haproxy/stats mode 600 level admin
    stats timeout 2m
    mode                    http
    option                  http-server-close
    option                  forwardfor       except 127.0.0.0/8
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
    maxconn                 3000
# Load Balancer Stick-Table Sync
peers lb_peers
    peer peer1 10.255.0.4:9969
    peer peer2 10.255.0.5:9969
# Stats interface
listen  stats
        bind            10.255.0.3:8080
        mode            http
        log             global
        maxconn 10
        timeout client      100s
        timeout server      100s
        timeout connect     100s
        timeout queue       100s
        stats hide-version
        stats refresh 30s
        stats show-node
        stats auth <REMOVED>
        stats uri /haproxy?stats
frontend  solarwinds_http_fe
    bind 10.255.0.3:80
    http-request set-header X-Forwarded-Proto http if !{ ssl_fc }
    default_backend solarwinds_be
frontend  solarwinds_https_fe
    bind 10.255.0.3:443 ssl crt /etc/ssl/solarwinds/solarwinds.pem
# Solarwinds backend
    stick-table type ip size 1 nopurge peers lb_peers
    stick on dst
    option httpchk HEAD /Orion/Login.aspx HTTP/1.1\r\nHost:\ mysite.domain.net
    server bru-monweb01 10.255.0.6:80 check fall 3 fastinter 5s downinter 5s rise 6
    server bru-monweb02 10.255.0.7:80 check fall 3 fastinter 5s downinter 5s rise 6 backup
