Hello community,
I’m trying to make a simple HAProxy Server Active-StandBy. I have 2 ports to handle, with two servers. What I have to do, is redirect requests from port 8123 and 1883 to respective ports on active server.
frontend ft_app
bind *:8123
bind *:1883
default_backend bk_app
backend bk_app
server node1-gui 192.168.2.50:8123 check
server node1-sonoff 192.168.2.51:1883 check
server node2-gui 192.168.2.51:8123 check backup
server node2-sonoff 192.168.2.51:1883 check backup
Unfortunately the above configuration doesn’t work (it doesn’t rederect to the server. If I configure the server in the following way, it works:
server node1-sonoff 192.168.2.50 check
server node2-gui 192.168.2.50 check backup
THe problem is that if the primary node goes down, HAProzy never route requests to the other node and the logs says:
[ALERT] 294/152920 (43307) : parsing [/usr/local/etc/haproxy.conf:11] : server s1 has neither service port nor check port nor tcp_check rule ‘connect’ with port information. Check has been disabled.
[ALERT] 294/152920 (43307) : parsing [/usr/local/etc/haproxy.conf:12] : server s2 has neither service port nor check port nor tcp_check rule ‘connect’ with port information. Check has been disabled.
Starting haproxy.
[ALERT] 294/152920 (43308) : parsing [/usr/local/etc/haproxy.conf:11] : server s1 has neither service port nor check port nor tcp_check rule ‘connect’ with port information. Check has been disabled.
[ALERT] 294/152920 (43308) : parsing [/usr/local/etc/haproxy.conf:12] : server s2 has neither service port nor check port nor tcp_check rule ‘connect’ with port information. Check has been disabled.
Could someone help me?
Thank you
Lucas
What happens is that a) you need to forward port 8123 on the haproxy instance to port 8123 on the backend server, and the same thing for 1883. However haproxy must not mix the two, because obviously they need to be separated.
This can be done by not specifying the destination port, like you already tried. The problem there is simply that you enabled health-checks, but without port information haproxy does not know what port to health-check.
You can specify the health-check port, without specifying the actual destination port with the port directive:
server node1 192.168.2.50 check port 8123
server node2 192.168.2.51 check port 8123 backup
However, perhaps the entire setup would be more straightforward (and the configuration easier to read) if you’d just separate the applications in the first place, using dedicated front and backends for gui vs sonoff:
frontend ft_app_gui
bind *:8123
default_backend bk_app_gui
frontend ft_app_sonoff
bind *:1883
default_backend bk_app_sonoff
backend bk_app_gui
server node1-sonoff 192.168.2.50:1883 check
Thank you @lukastribus it works perfect (I tried the config with separated applications)!!!
…and also thank you for explanation!
EDIT: DAMN! There is a downside with this config. If I shutdown the node1, all ports will be redirect to second server (node2). That’s ok! But when Node1 come up again, port 8123 will be redirect to node1 (ok!) but port 1883 remains on node2… This is not good for me because the requests must be redirect to the same node… Is there a way to avoid that behaviour?
Sessions that are up and running against a working server are never aborted/closed.
I assume one application here is a HTTP interface (GUI), which closes the sockets fast, therefor switching back to the primary server fast. The other application I guess is a long-lived TCP application, which does not close or switch, just because the primary server got back up, but stays on the backup server?
Is that assumption correct?
You can tell haproxy to shutdown sessions to backup-servers, that will probably meet your expectations, but you are going to kill a perfectly working connection to the backup server:
backend bk_app_gui
server node1-gui 192.168.2.50:8123 check on-marked-up shutdown-backup-sessions
server node1-sonoff 192.168.2.50:1883 check on-marked-up shutdown-backup-sessions
Or you could make sure the specific client IP address continuous to use the backup server, even after the primary server came backup, by using IP stickiness.
Yes, your assumption is correct. The port 8123 handles a web interface (hass.io - home assistant), so next http requests will be redirected to node1 when it comes up.
Instead, The port 1883 handles mosquitto server (for sonoff devices). So, when the lamps (sonoff) connect to backup server, even if primary server goes up, they remain connected to backup. That’s not correct, because otherwise I have GUI HASS.IO requests to primary, but sonoff devices connected to backup.
I’ll try your mod config asap (I’m not at home right now) and report it back. Thank you.
EDIT: Thank you, it works perfect now.
