Connectivity issue with standby roundrobin
I have configuration in haproxy to connect to two standby database servers (postgresql) in roundrobin fashion on one DB server I have configured pgbouncer with port 6432 and other database with db port 5432 but the haproxy always connects with 5432 port but when I manually connect with port 6432 I can from haporxy IP
PFA the haproxy config file:
[postgres@testbed06 haproxy]$ cat /etc/haproxy/haproxy.cfg
#chroot /var/lib/haproxy
timeout connect 5000ms
timeout client 5m # 10 minutes
timeout server 5m # 10 minutes
# timeout client-fin 10s
# timeout server-fin 10s
Stats configuration
# Set mode to HTTP
# Bind to port 8080
bind *:8080
# Enable stats
# Stats URI
stats uri /
Frontend for write operations on port 5000
frontend postgresql_write
bind 10.114.16.50:5000
Route all traffic to the write backend
default_backend write_backend
Frontend for read operations on port 5001
frontend postgresql_read
bind 10.114.16.50:5001
# Route all traffic to the read backend
default_backend read_backend
Backend for write operations (primary node)
option tcp-check
default-server inter 3s fall 3 rise 2
server primary_node 10.114.16.28:5432 check
Backend for read operations (secondary nodes)
option tcp-check
server secondary_node1 10.114.16.33:6432 check
server secondary_node2 10.114.16.34:5432 check
