Hi ,
We have HAProxy as a middleware for Kafka brokers on cloud ,
we have few clusters that might be created in the same domain suffix and we’d like to add routing for all using a unified wildcard ACL and Backend … is that can be done ?
for example -
frontend xxxx
bind *:443
acl is_ksql-xxxx req.ssl_sni -i pksqlc-*.somesuffix
use_backend ksql_xxxx if is_ksql-xxxx
backend ksql_xxxx
server ksql_xxxx pksqlc-*.somesuffix:443 check resolvers mynameservers init-addr last,libc,none
Can that be done at some method ? using the * wildcard instead of specific domain for supporting all kind of domains in the structure of pksqlc-*.somesuffix
such as -
pksqlc-1.somesuffix
pksqlc-2.somesuffix
pksqlc-3.somesuffix
pksqlc-4.somesuffix
