Any issues doing reverse proxy to a backend SSL connection?
I am working through an issue where I can’t quite get HAProxy 1.7 to properly reverse proxy to a non-SSL connection to the backend server (Tomcat server on port 8090). The config line that fails is:
server <myhost.domain.com>:8090 maxconn 1000
However, if I configure HAProxy to proxy to an SSL connection on the backend server (port 8443) using the following line, it proxies without issue:
server <myhost.domain.com>:8443 ssl verify none cookie s1 maxconn 1000
Is there any downside to proxying a front end SSL (443) to a backend SSL connection (8443)?
A few questions?
  • exactly what does fail mean? What error do you see?
  • what does curl -vv http://myhost.domain.com:8090 from the haproxy instance show?
  • why don’t you configure the cookie setting in the plaintext case?
  • what does the rest of the configuration, especially the frontend look like?
Certainly more load on the proxy and your backend comes to mind.
The error is that the browser comes back saying “Error 503 Service Unavailable. No server is available to handle this request.”
The result of curl is as follows:
GET / HTTP/1.1
User-Agent: curl/7.29.0
Host: <myhost.domain.com>:8090
Accept: /
< HTTP/1.1 302 Found
< Server: Apache-Coyote/1.1
< X-ASEN: SEN-10676748
< X-Confluence-Request-Time: 1517928298289
< X-Confluence-Cluster-Node: 386cbf39
< Set-Cookie: JSESSIONID=A13A927C9326F53452F421FFFA9C7E81; Path=/; Secure; HttpOnly
< X-XSS-Protection: 1; mode=block
< X-Content-Type-Options: nosniff
< X-Frame-Options: SAMEORIGIN
< Content-Security-Policy: frame-ancestors ‘self’
< Location: /login.action?os_destination=%2Findex.action&permissionViolation=true
< Content-Type: text/html;charset=UTF-8
< Content-Length: 0
< Date: Tue, 06 Feb 2018 14:44:58 GMT
The front end configuration is as follows:
frontend confluence_http_insecure
frontend confluence_http_secure
bind *:443 ssl crt /etc/pki/tls/keystore/.pem
reqadd X_Forwarded-Port:\ 443
default_backend confluence_http_backend
Additionally, this is what the Tomcat configuration looks like:
   <Connector port="8090">
             connectionTimeout="20000"
             redirectPort="8443"
             maxThreads="48" minSpareThreads="10"
             enableLookups="false"
             acceptCount="10"
             debug="0"
             URIEncoding="UTF-8"
             protocol="org.apache.coyote.http11.Http11NioProtocol"
             secure="true"
             scheme="https"
             proxyName="<myhost.domain.com>"
             proxyPort="443" />
Can you provide the “curl -vv” output against the frontend when the issue occurs (showing the 503 error) and can you provide the log message from haproxy (see example logging configuration)?
Here is the results of curl -vv <myhost.domain.com> I can’t determine if the 503 is being generated from the backend server, or the HAProxy:
About to connect() to <myhost.domain.com> port 443 (#0)
Trying 10.20.5.81…
Connected to wiki.corp.xperi.com (10.20.5.81) port 443 (#0)
Initializing NSS with certpath: sql:/etc/pki/nssdb
CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
Server certificate:
subject: CN=*.<mydomain.com,OU=Business Technologies,O=,L=San Jose,ST=CA,C=US
start date: Oct 31 00:00:00 2017 GMT
expire date: Nov 04 12:00:00 2020 GMT
common name: *.corp.xperi.com
issuer: CN=DigiCert SHA2 High Assurance Server CA,OU=www.digicert.com,O=DigiCert Inc,C=US
GET / HTTP/1.1
Accept: /
HTTP 1.0, assume close after body
HTTP/1.0 503 Service Unavailable
Cache-Control: no-cache
Connection: close
No server is available to handle this request. Closing connection 0
Its haproxy that is generating the 503. That’s why we need to see the haproxy log.
All the haproxy logging that I’m getting from the /var/log/syslog on the machine (CentOS 7.x) is the following:
2018-02-05T20:25:31-08:00 localhost haproxy[22525]: Proxy confluence_http_insecure started.
2018-02-05T20:25:31-08:00 localhost haproxy[22525]: Proxy confluence_http_secure started.
2018-02-05T20:25:31-08:00 localhost haproxy[22525]: Proxy confluence_http_backend started.
2018-02-05T20:28:03-08:00 localhost haproxy[22556]: Proxy confluence_http_insecure started.
2018-02-05T20:28:03-08:00 localhost haproxy[22556]: Proxy confluence_http_secure started.
2018-02-05T20:28:03-08:00 localhost haproxy[22556]: Proxy confluence_http_backend started.
2018-02-05T20:29:24-08:00 localhost haproxy[22577]: Proxy confluence_http_insecure started.
2018-02-05T20:29:24-08:00 localhost haproxy[22577]: Proxy confluence_http_secure started.
2018-02-05T20:29:24-08:00 localhost haproxy[22577]: Proxy confluence_http_backend started.
Please configure it like in this example here:
You’re referring to just changing:
log 127.0.0.1 local2 info
to:
log 127.0.0.1 syslog debug
And this is the compatible syntax for CentOS 7.x?
No, you need all of them.
