API accessed using DNS hostname stops responding
[root@XXXXXXXXXXXXXXX01 ~]# cat /etc/haproxy/haproxy.cfg
log /dev/log local0 info
timeout connect 10000
timeout client 45000
timeout server 24000
maxconn 50000
frontend firstpoint
bind XX.XXX.2.127:54321 transparent
timeout connect 100000
default_backend trackwizz
backend trackwizz
    timeout server 30000
    timeout connect 40000
    appsession ASP.Net_SessionID len 24 timeout 30m request-learn prefix
    server server1 XX.XXX.0.41:54321 check weight 1 fall 2 inter 1s rise 2
    server server2 XX.XXX.0.36:54321 check backup weight 1 fall 2 inter 1s rise 2
frontend secondpoint
bind XX.XXX.2.127:8011 transparent
default_backend trackwizz_2
backend trackwizz_2
server server1 XX.XXX.0.41:8011 check weight 1 fall 2 inter 1s rise 2
server server2 XX.XXX.0.36:8011 check weight 1 fall 2 inter 1s rise 2
frontend thirdpoint
bind XX.XXX.2.127:54322
default_backend trackwizz_3
backend trackwizz_3
server server1 XX.XXX.0.41:54322 check weight 1 fall 2 inter 1s rise 2
server server2 XX.XXX.0.36:54322 check weight 1 fall 2 inter 1s rise 2
frontend fourthpoint
bind XX.XXX.2.127:54323
default_backend trackwizz_4
backend trackwizz_4
server server1 XX.XXX.0.41:54323 check weight 1 fall 2 inter 1s rise 2
server server2 XX.XXX.0.36:54323 check weight 1 fall 2 inter 1s rise 2
listen status XX.XXX.2.144:8888
stats uri /hastatus
stats auth admin:12345678
[root@XXXXXXXXXXXXXXX ~]#
