I have inherited an existing reverse proxy configuration I’m trying to change that seems simple enough, but something isn’t working. The configuration that works uses port 9000 on the backend. I’m trying to change that to 9443, but when I do I am getting the following in the Chrome console:
"Failed to load the resource: the server responded with a status of 503 (Service Unavailable)"
I’ve used tcpdump -A -s 0 ‘tcp port 9443’ to try to verify that the server is seeing the request, but none appears.
My servers are using HAProxy 1.5.18 on CentOS 7.
The proxy server’s firewall accepts HTTPS on port 443.
The server’s firewall accepts TCP connections from the proxy server on ports 443 and 9000 (or 9443 as necessary).
The app’s functionality works fine in this configuration.
I’m not sure what to try next and would appreciate any help.
Thanks,
Scott
Here’s my HAProxy configuration:
Global settings
#Set the protocol
ssl-default-bind-options no-sslv3 force-tlsv12
#set the acceptable ciphers
ssl-default-bind-ciphers EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH
#debug
log 127.0.0.1 local2
chroot /var/lib/haproxy/haproxy pidfile /var/run/haproxy.pidfile
# max per-process number of connections
maxconn 256
# process's user and group
user haproxy group haproxy
# make the process fork into background
# turn on stats unix socket
defaults mode http
log global # the following enables logging of HTTP requests
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
# allow SSE and WebSocket connections to stay open for longer
timeout tunnel 8h
maxconn 3000
frontend main bind *:80
bind *:443 ssl crt /usr/local/glads/ssl/web.glads.stk.com.bundle.pem ca-file /usr/local/glads/ssl/ca-chain.cert.pem verify required crl-file /usr/local/glads/crl/combined.crl.pem
# allow access to the keycloak admin console to a select few ips or subnets.
acl network_allowed src 192.168.100.10/32
acl restricted_page path_beg -m beg -i /auth/admin/master/console http-request deny if restricted_page !network_allowed
http-request set-header X-SSL-Client-Cert %{+Q}[ssl_c_der,base64]
http-request set-header X-SSL-Issuer %{+Q}[ssl_c_i_dn]
#for logging purposes STIG V-69385
capture request header referer len 64
capture request header user-agent len 64
capture request header host len 100
capture request header connect len 20
#log-format %Tl\ %ci:%cp\ requestHeader=%hrl\ httpRequest=%redispatch
# Force SSL only
acl acl-glads-id path_beg /identity /auth/admin/master/console acl acl-glads-app path_beg /favicon.ico /glads-web acl acl-glads-app path_beg /glads acl acl-glads-app path_beg /help
acl acl-glads-wx path_beg /geoserver /geowebcache
acl acl-terrain path_beg /stk-terrain acl acl-chat path_beg /http-bind
use_backend glads-id if acl-glads-id use_backend glads-app if acl-glads-app use_backend stk-terrain if acl-terrain use_backend glads-wx if acl-glads-wx use_backend chat-srv if acl-chat
glads-id backend for serving identity
backend glads-id server glads_id c0007150-00.stk.com:443 ssl ca-file /usr/local/glads/ssl/ca-chain.cert.pem
glads-web backend for serving all things GLADS
backend glads-app server glads_app c0007151-00.stk.com:443 ssl ca-file /usr/local/glads/ssl/ca-chain.cert.pem
backend for serving terrain
backend stk-terrain server glads_terrain assets.agi.com:443 ssl ca-file /usr/local/glads/ssl/ca-chain.cert.pem
glads-wx backend for serving WMTS
backend glads-wx server glads_wx c0007151-00.stk.com:8443 ssl ca-file /usr/local/glads/ssl/ca-chain.cert.pem
chat-srv backend for serving EjabberD
backend chat-srv server ejabberd c0007151-00.stk.com:9443 ssl ca-file /usr/local/glads/ssl/ca-chain.cert.pem timeout server 90s
