# stats socket /var/lib/haproxy/stats
monitor-uri /health
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend main
bind *:8080
# route to a backend based on path's prefix
#default_backend web01
http-request capture req.hdr(Host) len 64
http-request capture req.hdr(Referer) len 64
http-request capture req.hdr(Content-Lenght) len 64
http-request capture req.hdr(User-Agent) len 64
use_backend tage1-publish if { path /tage1/publish } || { path_beg /tage1/publish/ }
use_backend tage1-carp if { path /tage1/carp } || { path_beg /tage1/carp/ }
use_backend tage1-lhc if { path /tage1/lhc } || { path_beg /tage1/lhc/ }
http-request replace-path /tage1/publish(/)?(.*) /\2
server tage1-publish-1 10.607.554.100:8080
backend tage1-carp
option log-health-checks
http-request add-header X-Forwarded-Port 443
http-request replace-path /tage1/carp(/)?(.*) /\2
server tage1-carp-1 team-acptage1-carppedicare.lhc.com ssl verify none
backend tage1-lhc
http-request replace-path /tage1/lhc(/)?(.*) /\2
server tage1-uhc-1 team-acptage1-lhcpedicare.lhc.com ssl verify none
bind *:8888
stats hide-version
stats refresh 30s
stats show-node
stats auth rproxy:P@ssw0rd
stats uri /stats
Part of my config works but the other part doesn’t.
I am using the example.com instead of the actual hostname. Sorry if that makes the urls unreadable.
[Works In Browser] http://www.example.com/health
[Works In Browser] http://www.example.com/tage1/publish
[Browser returns 503] http://www.example.com/tage1/carp
[Browser returns 503] http://www.example.com/tage1/lhc
When I log into the pod and run a curl command the following are the results.
[503] http://localhost:8080/tage1/carp
[503] http://localhost:8080/tage1/lhc
[200] team-acptage1-carppedicare.lhc.com
[200] team-acptage1-lhcpedicare.lhc.com
So, from the pod curl to the backend urls works fine. So it is haproxy where the issue lies and by extension the issue is in my configuration.
However, I don’t know what is it that is misconfigured.
