Good day! I have some problems with backend and receive 503 response from web. We used http mode by default. All incoming requests checked and forwarded to 443 ssl. But one of them (backend) not worked on http mode. It requires only tcp mode for background. Can i use frontend http and forward it ti backend with tcp mode?
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_LINUX_TPROXY=1 USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
#log 127.0.0.1 local2
log /dev/log local0 info
log /dev/log local0 notice
pidfile /var/run/haproxy.pid
maxconn 4000
log-format {“haproxy_clientIP”:"%ci",“haproxy_clientPort”:"%cp",“haproxy_dateTime”:"%t",“haproxy_frontendNameTransport”:"%ft",“haproxy_backend”:"%b",“haproxy_serverName”:"%s",“haproxy_Tw”:"%Tw",“haproxy_Tc”:"%Tc",“haproxy_Tt”:"%Tt",“haproxy_bytesRead”:"%B",“haproxy_terminationState”:"%ts",“haproxy_actconn”:%ac,“haproxy_FrontendCurrentConn”:%fc,“haproxy_backendCurrentConn”:%bc,“haproxy_serverConcurrentConn”:%sc,“haproxy_retries”:%rc,“haproxy_srvQueue”:%sq,“haproxy_backendQueue”:%bq,“haproxy_backendSourceIP”:"%bi",“haproxy_backendSourcePort”:"%bp",“haproxy_statusCode”:"%ST",“haproxy_serverIP”:"%si",“haproxy_serverPort”:"%sp",“haproxy_frontendIP”:"%fi",“haproxy_frontendPort”:"%fp",“haproxy_capturedRequestHeaders”:"%hr",“haproxy_httpRequest”:"%r"}
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
bind vip:8404
stats hide-version
stats uri /stats
option httpclose
stats auth haproxy:Qazwsx!@
frontend https
bind vip:80
bind vip:443 ssl crt /etc/haproxy/ssl/cbar.cer ca-file /etc/haproxy/ssl/cbar-ca.cer crt /etc/haproxy/ssl/ecbar.cer ca-file /etc/haproxy/ssl/ecbar-ca.cer crt /etc/haproxy/ssl/bizimpullar.az.cer ca-file /etc/haproxy/ssl/bizimpullar.az-ca.cer
http-request set-header X-SSL %[ssl_fc]
http-request set-header X-SSL-Client-Verify %[ssl_c_verify]
http-request set-header X-SSL-Client-SHA1 %{+Q}[ssl_c_sha1]
http-request set-header X-SSL-Client-DN %{+Q}[ssl_c_s_dn]
http-request set-header X-SSL-Client-CN %{+Q}[ssl_c_s_dn(cn)]
http-request set-header X-SSL-Issuer %{+Q}[ssl_c_i_dn]
http-request set-header X-SSL-Client-Not-Before %{+Q}[ssl_c_notbefore]
http-request set-header X-SSL-Client-Not-After %{+Q}[ssl_c_notafter]
acl url_accr hdr_dom(host) -i accr.cbar.az
acl url_accr hdr_dom(host) -i www.accr.cbar.az
use_backend backend_accr if url_accr
option tcp-check
#redirect location [https://accr.cbar.az](https://accr.cbar.az/) ##!/login
option tcp-check
server accr-act mybackip:443 check port 443 fall 3 rise 2 ssl ca-file /etc/haproxy/ssl/cbar-ca.cer
Maybe the backend server needs SNI?
Does it work without health checks?
no it doesnt
Either your backend requires SNI, uses a certificate that cannot be authenticated with the ca file /etc/haproxy/ssl/cbar-ca.cer or there is some other SSL related problem.
Try verify none on the server line. If that also doesn’t work, try capturing the SSL traffic between haproxy and the backend, also make a curl -vvl https://.. request against that backend server from the haproxy instance.
