Hi Team
we need your help to resolve the issue, we are getting 503 error intermittently for our servers.
haproxy configuration:
#log 127.0.0.1 local2 debug
log 127.0.0.1:514 local0 debug
pidfile /var/run/haproxy.pid
maxconn 10000
debug
# turn on stats unix socket
default
timeout http-request 30s
timeout queue 1m
timeout connect 30s
timeout client 1m
timeout server 1m
timeout http-keep-alive 30s
timeout check 30s
maxconn 10000
backend activation-backend
http-send-name-header Host
http-response add-header XX-powered-by “West-1”
server XXXXXXX.com:443 XXXXXXX.com:443 check ssl verify none
output : for haproxy -vv
HA-Proxy version 1.8.27-493ce0b 2020/11/06
Copyright 2000-2020 Willy Tarreau willy@haproxy.org
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -W no-null-dereference -Wno-unused-label -Wno-stringop-overflow
OPTIONS = USE_LINUX_TPROXY=1 USE_CRYPT_H=1 USE_GETADDRINFO=1 USE_ZLIB=1 USE_RE GPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.1.1g FIPS 21 Apr 2020
Running on OpenSSL version : OpenSSL 1.1.1k FIPS 25 Mar 2021
Built with transparent proxy support using: IP_TRANSPARENT IPV6_TRANSPARENT IP_F REEBIND
Built with PCRE version : 8.42 2018-03-20
Running on PCRE version : 8.42 2018-03-20
Compression algorithms supported : identity(“identity”), deflate(“deflate”), raw -deflate(“deflate”), gzip(“gzip”)
errors: May 26 10:16:31 localhost haproxy[4083320]: Server xxxxx-backend/XXXXX.com:443 is DOWN, reason: Layer6 timeout, check duration: 2002ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue
Message from syslogd@localhost at May 30 02:32:33 …
haproxy[104161]: backend activation-backend has no server available!
any possible solutions to resolve the issue.
