Getting 503 errors with <NOSRV> in backend and Layer6 timeout error log
Hi
We are using HA Proxy v2.6.15 on Ubuntu 18.04.6 LTS and getting 503 errors in API hits. This behaviour is occurring on when loading the HA Proxy load balancer with some 100 tps load.
While checking the logs, it shows below errors:
Apr 18 06:54:08 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server3:8081-28c6a60e is UP, reason: Layer6 check passed, check duration: 14ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Apr 18 06:54:08 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server1:8081-28c6a60e is UP, reason: Layer6 check passed, check duration: 15ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Apr 18 06:54:08 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server2:8081-28c6a60e is UP, reason: Layer6 check passed, check duration: 14ms. 3 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
^[[CApr 18 06:54:45 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server3:8081-28c6a60e is DOWN, reason: Layer6 timeout, check duration: 2002ms. 2 active and 0 backup servers left. 265 sessions active, 0 requeued, 0 remaining in queue.
Apr 18 06:54:45 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server1:8081-28c6a60e is DOWN, reason: Layer6 timeout, check duration: 2003ms. 1 active and 0 backup servers left. 267 sessions active, 0 requeued, 0 remaining in queue.
Apr 18 06:54:46 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server2:8081-28c6a60e is DOWN, reason: Layer6 timeout, check duration: 2006ms. 0 active and 0 backup servers left. 271 sessions active, 0 requeued, 0 remaining in queue.
Apr 18 06:54:46 haproxy-server-1 haproxy[29108]: [ALERT] (29112) : backend ‘bck_nodes’ has no server available!
Apr 18 06:55:03 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server2:8081-28c6a60e is UP, reason: Layer6 check passed, check duration: 15ms. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Apr 18 06:55:03 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server1:8081-28c6a60e is UP, reason: Layer6 check passed, check duration: 16ms. 2 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
Apr 18 06:55:03 haproxy-server-1 haproxy[29108]: [WARNING] (29112) : Server backend-server3:8081-28c6a60e is UP, reason: Layer6 check passed, check duration: 17ms. 3 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
haproxy -vv Output:
HAProxy version 2.6.15-446b02c 2023/08/09 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2027.
Known bugs: http://www.haproxy.org/bugs/bugs-2.6.15.html
Running on: Linux 4.15.0-163-generic #171-Ubuntu SMP Fri Nov 5 11:55:11 UTC 2021 x86_64
TARGET = generic
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wundef -Wdeclaration-after-statement -Wfatal-errors -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wno-string-plus-int -Wno-atomic-alignment
OPTIONS = USE_PCRE=1 USE_LINUX_TPROXY=1 USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_SLZ=1 USE_TFO=1 USE_SYSTEMD=1 USE_PROMEX=1
Feature list : -51DEGREES -ACCEPT4 -BACKTRACE -CLOSEFROM -CPU_AFFINITY -CRYPT_H -DEVICEATLAS -DL -ENGINE -EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBCRYPT -LINUX_SPLICE +LINUX_TPROXY +LUA -MEMORY_PROFILING -NETFILTER -NS -OBSOLETE_LINKER +OPENSSL -OT +PCRE -PCRE2 -PCRE2_JIT -PCRE_JIT +POLL -PRCTL -PROCCTL +PROMEX -QUIC -RT +SLZ -STATIC_PCRE -STATIC_PCRE2 +SYSTEMD +TFO -THREAD -THREAD_DUMP +TPROXY -WURFL -ZLIB
Built without multi-threading support (USE_THREAD not set).
Encrypted password support via crypt(3): no
Built with gcc compiler version 7.5.0
Total: 2 (2 usable), will use poll.
: mode=HTTP side=FE|BE mux=H1 flags=HTX
: mode=TCP side=FE|BE mux=PASS flags=
[FCGI] fcgi-app
haproxy.cfg
log 127.0.0.1 local0
log 127.0.0.1 local1 notice
maxconn 30000
stats socket /tmp/haproxy.sock mode 600 level user
tune.ssl.default-dh-param 1024
ssl-dh-param-file /etc/haproxy/dhparam
ssl-default-bind-ciphers ALL:!aNULL:-ECDHE-RSA-RC4-SHA:-RC4-SHA:-RC4-MD5:-EDH-RSA-DES-CBC-SHA:-DES-CBC-SHA:-AECDH-AES256-SHA:-AECDH-AES128-SHA
ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tls-tickets
ssl-default-server-ciphers ALL:!aNULL:-ECDHE-RSA-RC4-SHA:-RC4-SHA:-RC4-MD5:-EDH-RSA-DES-CBC-SHA:-DES-CBC-SHA:-AECDH-AES256-SHA:-AECDH-AES128-SHA
compression algo gzip
compression type text/html text/plain text/css text/javascript
maxconn 30000
fullconn 9000
timeout connect 60s
timeout client 600s
timeout server 600s
log-format ‘{“client_ip”: “%ci”,“client_port”: %cp,“date_time”: “%t”,“frontend_name_transport”: “%ft”,“backend_name”: “%b”,“server_name”: “%s”,“time_waited_for_client”: %Tq,“time_spent_in_queues”: %Tw,“time_waited_for_stablish_connection”: %Tc,“time_spent_waiting_for_full_http”: %Tr,“time_between_accept_and_close”: %Tt,“status_code”: %ST,“bytes_read”: %B,“captured_request_cookie”: “%CC”,“captured_respose_cookie”: “%CS”,“termination_state_with_cookie”: “%tsc”,“actconn”: “%ac”,“feconn”: “%fc”,“beconn”: “%bc”,“srv_conn”: “%sc”,“retries”: %rc,“srv_queue”: “%sq”,“backend_queue”: “%bq”,“http_method”: “%HM”,“http_path”: “%HP”,“ssl_ciphers”: “%sslc”,“ssl_version”: “%sslv”,“tls-warn”:“%[var(txn.tlswarn)]”,“bytes_uploaded”: %U}’
frontend http
http-response set-header Strict-Transport-Security max-age=63072000
frontend https
bind *:443 ssl crt /etc/haproxy/pem/cert.pem alpn h2,http/1.1 ssl-min-ver TLSv1.0
acl bck_mgmt path_beg /mgmt
use_backend reject_bck_mgmt if bck_mgmt
default_backend bck_nodes
errorfile 503 /etc/haproxy/errors/404.http
backend bck_nodes
acl is_ssl_version_deprecated ssl_fc_protocol SSLv3 TLSv1 TLSv1.1
http-request set-header X-Forwarded-Host %[req.hdr(Host)]
http-request set-header tls-version %sslv
##ROUTES BEGIN
server backend-server1:8081-28c6a60e backend-server1:8081 weight 1 check inter 2000 rise 2 fall 2 ssl verify none
server backend-server2:8081-28c6a60e backend-server2:8081 weight 1 check inter 2000 rise 2 fall 2 ssl verify none
server backend-server3:8081-28c6a60e backend-server3:8081 weight 1 check inter 2000 rise 2 fall 2 ssl verify none
##ROUTES END
listen admin
bind *:22002
stats uri /
stats refresh 5s
We are also facing this issue with upgrading the HA Proxy to this version with similar configuraiton. It is working with 1.8.8.
Looking for guidance from experts here.
