Haproxy throwing intermittent 503, Backend server not available for layer6 timeout
Hi Team
Please we need your help to resolve an issue we are having. We are getting 503 error intermittently for our servers.
haproxy configuration:
#log 127.0.0.1 local2 debug
log 127.0.0.1:514 local0 debug
pidfile /var/run/haproxy.pid
maxconn 10000
debug
turn on stats unix socket
default
mode                    http
retries                 3
timeout http-request    30s
timeout queue           1m
timeout connect         30s
timeout client          1m
timeout server          1m
timeout http-keep-alive 30s
timeout check           30s
maxconn                 10000
backend activation-backend
http-send-name-header Host
http-response add-header XX-powered-by “West-1”
server XXXXXXX.com:443 XXXXXXX.com:443 check ssl verify none
output : for haproxy -vv
HA-Proxy version 1.8.27-493ce0b 2020/11/06
Copyright 2000-2020 Willy Tarreau willy@haproxy.org
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -W no-null-dereference -Wno-unused-label -Wno-stringop-overflow
OPTIONS = USE_LINUX_TPROXY=1 USE_CRYPT_H=1 USE_GETADDRINFO=1 USE_ZLIB=1 USE_RE GPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.1.1g FIPS 21 Apr 2020
Running on OpenSSL version : OpenSSL 1.1.1k FIPS 25 Mar 2021
Built with transparent proxy support using: IP_TRANSPARENT IPV6_TRANSPARENT IP_F REEBIND
Built with PCRE version : 8.42 2018-03-20
Running on PCRE version : 8.42 2018-03-20
Compression algorithms supported : identity(“identity”), deflate(“deflate”), raw -deflate(“deflate”), gzip(“gzip”)
errors: May 26 10:16:31 localhost haproxy[4083320]: Server xxxxx-backend/XXXXX.com:443 is DOWN, reason: Layer6 timeout, check duration: 2002ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue
Message from syslogd@localhost at May 30 02:32:33 …
haproxy[104161]: backend activation-backend has no server available!
any possible solutions to resolve the issue.
From the error message, it seems HAProxy was not able to establish an SSL connection with the server. TCP worked, but not SSL. Maybe your server expect an SNI. In such case, you may want to try this: HAProxy version 2.4.15 - Configuration Manual
Use the value behind the XXXXXXX.com
