I am a newbee to HAProxy world. I am testing HAProxy as Reverse Proxy(RP) as well as Load Balancer(LB) for our internal software environment. Please note that before posting this question, i checked other topics with httpchk health check issue and not found any solution.
I tried using Apache as RP and LB and it was working fine.
Can you please help me in this case? Kindly let me know if you need more information from myside.
Information about setup:
- HAProxy as RP and LB (version 1.5.19)
- Backend is Tomcat setup with http ports
- 6 different Application in the environment
HAProxy with httpchk is working fine only for 1 application.
Here is output of ./haproxy -vv
HA-Proxy version 1.5.19 2016/12/25
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing
OPTIONS = USE_OPENSSL=1
Built without zlib support (USE_ZLIB not set)
Compression algorithms supported : identity
Built without PCRE support (using libc’s regex instead)
##Configuration(working)
frontend TEST1_FE
bind *:543 ssl crt /home/data/hacert/server1.pem
capture cookie SERVERID len 63
acl pass_node path_sub test1
use_backend TEST1_BE if pass_node
default_backend TEST1_BE
backend TEST1_BE
option httpchk OPTIONS /test1/ HTTP/1.0
cookie SERVERID insert indirect nocache secure httponly
server server1 IP_of_machine1:8090 cookie node-sv1 check on-marked-down shutdown-sessions
server server2 IP_of_machine2:8090 cookie node-sv2 check on-marked-down shutdown-sessions
reqadd X-Forwarded-port:\ 543
reqadd X-Forwarded-proto:\ https
http-send-name-header x-dsp-client-node
For other applications httpchk is not working and causing error “backend has no server available!”. I tried various methods in httpchk, but they are not working and giving same error. If i remove httpchk other applications are working fine.
If i hit the URL from browser, it is givin 503 response with following configuration. URL is https like "https://test2-hostname.mydomain.com:545/test2. URL pattern is same for all applications
##Configuration(not working) -
frontend TEST2_FE
bind *:545 ssl crt /home/data/hacert/server1.pem
capture request header origin len 63
http-response add-header Access-Control-Allow-Origin %[capture.req.hdr(0)]
acl test2_node path_sub test2
use_backend TEST2_BE if test2_node
default_backend TEST2_BE
backend TEST2_BE
option httpchk OPTIONS /test2/ HTTP/1.0\r\nHOST:\test2-hostname.mydomain.com
server members for load balancing - TOMCAT
server server1 IP_of_machine1:9020 cookie node-sv1 check on-marked-down shutdown-sessions
server server2 IP_of_machine2:9020 cookie node-sv2 check on-marked-down shutdown-sessions
reqadd X-Forwarded-port:\ 545
Thank you in advance for your help.
