I want to bind http entrance connection in HA-Proxy version 1.8.8-1ubuntu0.1.
I am using bind keyword, but it’s not functionnel.
The binding instruction is : bind *:80
Please help me.
Thanks in advance.
Please help me.
Thanks in advance.
Maybe you could elaborate the problem a little bit?
Ok !
I’m configuring haproxy and i want to add the frontend part.
In this part, i want to bind the HTTP traffic,
I’m using the bind keyword but it’s not working.
And what does not working mean? Do you get any error message while starting haproxy? If yes, it would be a good idea to share that error message.
Thanks.
The whole configuration is
maxconn 5000
timeout connect 2m
timeout client 2m
timeout server 2m
frontend www-http
option httpclose
redirect prefix https://www.example.com if { hdr(host) -i example.com }
THe error when i start :
Process: 1982 ExecStart=/usr/sbin/haproxy -Ws -f $CONFIG -p $PIDFILE $EXTRAOPTS (code=exited, status=1/FAILURE)
Process: 1981 ExecStartPre=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS (code=exited, status=0/SUCCESS)
Main PID: 1982 (code=exited, status=1/FAILURE)
Sep 01 10:49:57 vps-2728-nextwab systemd[1]: haproxy.service: Service hold-off time over, scheduling restart.
Sep 01 10:49:57 vps-2728-nextwab systemd[1]: haproxy.service: Scheduled restart job, restart counter is at 5.
Sep 01 10:49:57 vps-2728-nextwab systemd[1]: Stopped HAProxy Load Balancer.
Sep 01 10:49:57 vps-2728-nextwab systemd[1]: haproxy.service: Start request repeated too quickly.
Sep 01 10:49:57 vps-2728-nextwab systemd[1]: haproxy.service: Failed with result ‘exit-code’.
Sep 01 10:49:57 vps-2728-nextwab systemd[1]: Failed to start HAProxy Load Balancer.
Provide the output of:
haproxy -vvhaproxy -f /real/path/to/haproxy.cfg -cThanks.
The result of haproxy -vv
HA-Proxy version 1.8.8-1ubuntu0.1 2018/05/29
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fdebug-prefix-map=/build/haproxy-VmwZ9X/haproxy-1.8.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_NS=1
Built with OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
Running on OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
And the result of haproxy -f /real/path/to/haproxy.cfg -c is :
Configuration file is valid
I think you only triggered some systemd threshold that now impedes to start haproxy.
Wait a few seconds, and start haproxy (systemctl start haproxy).
Thanks,
But it does not work.
Please, can you advise another solution?
Do:
systemctl stop haproxy
sleep 60
systemctl status haproxy
Thanks.
I was find the solution.
The problem was that i have installed apache service in same server.
So when hapoxy proxy try to bind trafic on 80 port, it could not because this port was already used by apache service.
I just stop apache service and haproxy starts correctly.
Thanks again for your help
