Getting Error While starting haproxy
[root@haproxy_restored haproxy]# haproxy -c -f haproxy.cfg
Configuration file is valid
[root@haproxy_restored haproxy]# systemctl restart haproxy.service
[root@haproxy_restored haproxy]# systemctl status haproxy.service
Loaded: loaded (/usr/lib/systemd/system/haproxy.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Fri 2020-08-14 15:04:27 +0530; 4s ago
Process: 4310 ExecStart=/usr/sbin/haproxy-systemd-wrapper -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid $OPTIONS (code=exited, status=1/FAILURE)
Main PID: 4310 (code=exited, status=1/FAILURE)
Aug 14 15:04:27 haproxy_restored haproxy-systemd-wrapper[4310]: [ALERT] 226/150427 (4311) : Starting proxy xcurrent_coinone1_l2: cannot bind socket…4:5000]
Aug 14 15:04:27 haproxy_restored haproxy-systemd-wrapper[4310]: [ALERT] 226/150427 (4311) : Starting proxy xcurrent_coinone2_l2: cannot bind socket…4:3999]
Aug 14 15:04:27 haproxy_restored haproxy-systemd-wrapper[4310]: [ALERT] 226/150427 (4311) : Starting proxy xcurrent_coinone3_l3: cannot bind socket…4:3002]
Aug 14 15:04:27 haproxy_restored haproxy-systemd-wrapper[4310]: [ALERT] 226/150427 (4311) : Starting proxy xcurrent_coinone4_l4: cannot bind socket…4:3009]
Aug 14 15:04:27 haproxy_restored haproxy-systemd-wrapper[4310]: [ALERT] 226/150427 (4311) : Starting proxy xcurrent_sabb1_l1: cannot bind socket [1…44:443]
Aug 14 15:04:27 haproxy_restored haproxy-systemd-wrapper[4310]: [ALERT] 226/150427 (4311) : Starting proxy kapruka: cannot bind socket [192.168.5.44:8080]
Aug 14 15:04:27 haproxy_restored haproxy-systemd-wrapper[4310]: haproxy-systemd-wrapper: exit, haproxy RC=1
Aug 14 15:04:27 haproxy_restored systemd[1]: haproxy.service: main process exited, code=exited, status=1/FAILURE
Aug 14 15:04:27 haproxy_restored systemd[1]: Unit haproxy.service entered failed state.
Aug 14 15:04:27 haproxy_restored systemd[1]: haproxy.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
Can you should the output of:
haproxy -vv
cat /usr/lib/systemd/system/haproxy.service
Also please explain what OS you have and the install history of haproxy here.
[root@haproxy_restored ~]# haproxy -vv
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_LINUX_TPROXY=1 USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
[root@haproxy_restored ~]# cat /usr/lib/systemd/system/haproxy.service
[Unit]
After=syslog.target network.target
[Service]
EnvironmentFile=/etc/sysconfig/haproxy
KillMode=mixed
[Install]
WantedBy=multi-user.target
[root@haproxy_restored ~]# cat /etc/redhat-release
Red Hat Enterprise Linux Server release 7.8 (Maipo)
You probably cannot bind to those IP:port combination, either because the IP does not exist or because there already is another application bound to those ports.
Did you check that?
Thanks. It is already bound to another application.
