Hello world!
I’m trying to start haproxy, however unable to do so:
# haproxy -v
HAProxy version 2.9.6-9eafce5 2024/02/26 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2025.
Known bugs: http://www.haproxy.org/bugs/bugs-2.9.6.html
Running on: FreeBSD 14.0-RELEASE-p6 FreeBSD 14.0-RELEASE-p6 #0: Tue Mar 26 20:26:20 UTC 2024 root@amd64-builder.daemonology.net:/usr/obj/usr/src/amd64.amd64/sys/GENERIC amd64
# service haproxy start
Starting haproxy.
I don’t see any messages in /var/log/messages, and meanwhile service is still trying to start…
haproxy.conf, :
# cat /usr/local/etc/haproxy.conf
# generated 2024-05-12, Mozilla Guideline v5.7, HAProxy 2.9.6, OpenSSL 3.0.12, modern configuration
# https://ssl-config.mozilla.org/#server=haproxy&version=2.9.6&config=modern&openssl=3.0.12&guideline=5.7
# modern configuration
ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tlsv10 no-tlsv11 no-tlsv12 no-tls-tickets
ssl-default-server-options no-sslv3 no-tlsv10 no-tlsv11 no-tlsv12 no-tls-tickets
timeout client 30s
timeout server 30s
frontend ft_66
bind :443 ssl crt /usr/local/etc/...pem alpn h2,http/1.1
# bind :80
default_backend be_66
# HSTS (63072000 seconds)
http-response set-header Strict-Transport-Security max-age=63072000
backend be_66
server apache24 localhost:80 check
Please advise)
Thanks in advance!
