I would like to block all requests that use any of the ip addresses of the server as host. Is there an easier way than acl is_ip hdr(host) -i 1.2.3.4 -i 4.3.2.1?
Greetings
Greetings
Well, any ip addresses than really, right? I suggest you use regular expressions.
Can I just use acl is_ip hdr(host) -i \d{1,3}.\d{1,3}.\d{1,3}.\d{1,3}? Or how does that work?
Yes, just call -m reg and also escape the dot:
acl is_ip hdr(host) -i -m reg \d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}
