Hi, I’m trying to implement a Wordpress bruteforce protection at haproxy level, version 1.5.18 in CentOS 7. I’m folowing the manual https://www.haproxy.com/blog/wordpress-cms-brute-force-protection-with-haproxy/ but I’m not able to make it work.
In the frontend section I have:
tcp-request inspect-delay 10s
tcp-request content accept if HTTP
acl wp_login path_beg -i /wp-login.php
acl flagged_as_abuser sc1_get_gpc0 gt 0
stick-table type binary len 20 size 500 store gpc0
tcp-request content track-sc1 base32+src if METH_POST wp_login
http-request deny if flagged_as_abuser
In the backend section I have:
stick-table type binary len 20 size 500 store gpc0,http_req_rate(5s)
tcp-request content track-sc2 base32+src if METH_POST wp_login
stick store-request base32+src if METH_POST wp_login
acl bruteforce_detection sc2_http_req_rate gt 5
acl flag_bruteforce sc1_inc_gpc0 gt 0
http-request deny if bruteforce_detection flag_bruteforce
Whe I show the table in the backend I see that the http_req_rate always has zero value:
# table: webphp56_servers, type: binary, size:500, used:6
0x5578f86675e4: key=3AAE35AFC1C9E0C1000000000000000000000000 use=0 exp=0 server_id=10 gpc0=0 http_req_rate(5000)=0
0x5578f8907874: key=4C6CF94FBB10374B000000000000000000000000 use=0 exp=0 server_id=10 gpc0=0 http_req_rate(5000)=0
0x5578f8a994f4: key=CE6B86EB8ACC472F000000000000000000000000 use=0 exp=0 server_id=7 gpc0=0 http_req_rate(5000)=0
What am I doing wrong?
Thank you in advance.
