Hello
I have a HAProxy server (1.5.8) in front of an Owncloud server (9.1.0).
I can register an iOS or Android device to my Owncloud agendas (using CalDav) but when it comes to using Mac OS X calendar client it does not work ! I have an error on the client side saying the username / password cannot be verified. If I bypass HAProxy and connects to the Owncloud server directly it works just fine.
HAProxy config:
log 127.0.0.1 local0
#log 127.0.0.1 local1 notice
# For more information, see ciphers(1SSL).
ssl-default-bind-ciphers EDH+CAMELLIA:EDH+aRSA:EECDH+aRSA+AESGCM:EECDH+aRSA+SHA384:EECDH+aRSA+SHA256:EECDH:+CAMELLIA256:+AES256:+CAMELLIA128:+AES128:+SSLv3:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!DSS:!RC4:!SEED:!ECDSA:CAMELLIA256-SHA:AES256-SHA:CAMELLIA128-SHA:AES128-SHA
ssl-default-bind-options no-sslv3 no-tls-tickets #disable SSLv3
tune.ssl.default-dh-param 2048 #tune DH to 2048
frontend public
bind *:443 ssl crt /etc/haproxy/letsencrypt/
acl owncloud hdr(host) -i owncloud.myserver.com
use_backend owncloud_server if owncloud
#rspadd Strict-Transport-Security:\ max-age=15768000;\ includeSubDomains #enable HSTS header for this backend
rspadd X-XSS-Protection:\ 1;\ mode=block #enable XSS protection for this backend
option httpclose
cookie JSESSIONID prefix
server srv01 10.10.10.101:80 cookie A check
Here are the logs from the HAProxy server when I try to register my Mac OS X client:
Aug 30 13:00:08 localhost haproxy[9586]: 10.10.10.119:47998 [30/Aug/2016:13:00:08.487] public~ owncloud_server/srv01 208/0/1/0/209 301 577 - - --NN 0/0/0/0/0 0/0 “PROPFIND /.well-known/caldav HTTP/1.1”
Aug 30 13:00:08 localhost haproxy[9586]: 10.10.10.119:48006 [30/Aug/2016:13:00:08.744] public~ owncloud_server/srv01 56/0/0/85/141 405 998 - - --NN 0/0/0/0/0 0/0 “PROPFIND / HTTP/1.1”
Aug 30 13:00:09 localhost haproxy[9586]: 10.10.10.119:48012 [30/Aug/2016:13:00:08.932] public~ owncloud_server/srv01 52/0/0/85/137 405 1002 - - --NN 0/0/0/0/0 0/0 “PROPFIND /caldav/v2 HTTP/1.1”
Aug 30 13:00:09 localhost haproxy[9586]: 10.10.10.119:48016 [30/Aug/2016:13:00:09.122] public~ owncloud_server/srv01 54/0/0/82/136 405 1002 - - --NN 0/0/0/0/0 0/0 “PROPFIND /principals/users/Alex/ HTTP/1.1”
Aug 30 13:00:09 localhost haproxy[9586]: 10.10.10.119:48024 [30/Aug/2016:13:00:09.305] public~ owncloud_server/srv01 18/0/0/81/99 405 998 - - --NN 0/0/0/0/0 0/0 “PROPFIND /principals/ HTTP/1.1”
Aug 30 13:00:09 localhost haproxy[9586]: 10.10.10.119:48030 [30/Aug/2016:13:00:09.455] public~ owncloud_server/srv01 65/0/0/82/147 405 1014 - - --NN 0/0/0/0/0 0/0 “PROPFIND /dav/principals/ HTTP/1.1”
Logs when I register an iOS client:
Aug 30 13:23:24 localhost haproxy[9586]: 10.10.10.119:34846 [30/Aug/2016:13:23:24.009] public~ owncloud_server/srv01 122/0/1/53/176 401 1319 - - --NN 0/0/0/0/0 0/0 “PROPFIND /remote.php/dav/principals/users/Alex/ HTTP/1.1”
Aug 30 13:23:24 localhost haproxy[9586]: 10.10.10.119:34854 [30/Aug/2016:13:23:24.242] public~ owncloud_server/srv01 58/0/0/148/206 207 1697 - - --NN 0/0/0/0/0 0/0 “PROPFIND /remote.php/dav/principals/users/Alex/ HTTP/1.1”
Aug 30 13:23:24 localhost haproxy[9586]: 10.10.10.119:34864 [30/Aug/2016:13:23:24.512] public~ owncloud_server/srv01 26/0/0/150/176 200 1653 - - --NN 0/0/0/0/0 0/0 “OPTIONS /remote.php/dav/principals/users/Alex/ HTTP/1.1”
Any idea ?
