Cannot get "redirect scheme" to work in backend section
Hi, I have a haproxy cluster with two frontends for http and https and many backends which are selected using a domain2backend map.
Some of the backends must be accessed only through HTTPS.
I tried using redirect scheme https code 301 if !{ ssl_fc } in those backends but haproxy seems to be ignoring it.
Configuration excerpt:
   maxconn 1024
   debug
   log /sidecar/log local0 debug
   stats socket /var/run/haproxy.sock mode 600 level admin
   stats timeout 2m
    maxconn 32
    monitor-uri /haproxy_test
frontend http-in
    use_backend %[req.hdr(host),lower,map_dom(/usr/local/etc/haproxy/domain2backend.map)]
frontend https-in
    bind *:443 ssl crt /usr/local/etc/haproxy/ssl
    http-request add-header X-Proto https if { ssl_fc }
backend redmine_www
    server 10.19.12.253:5200 10.19.12.253:5200 check
    server 10.19.11.197:5200 10.19.11.197:5200 check
    server 10.19.13.150:5200 10.19.13.150:5200 check
I am using haproxy version 1.7.3
/ # haproxy -vv
HA-Proxy version 1.7.3 2017/02/28
Copyright 2000-2017 Willy Tarreau <willy@haproxy.org>
  TARGET  = linux2628
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement
  OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2k  26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k  26 Jan 2017
I have been looking for a solution and trying different options without any success.
I would appreciate any help.
Thanks.
P.S. Also in StackOverflow: http://stackoverflow.com/questions/42699540/haproxy-redirect-scheme-in-backend-not-working
The redirect would probably work, but I don’t think the variable ssl_fc is available in a backend.
Can you verify if it works without the “if !{ ssl_fc }”?
Try accessing the X-Proto header, like
redirect scheme https code 301 if !{ hdr(X-Proto) -m str https }
Hi Lukas, thanks for your time,
I have just tried without the condition and it does not work.
backend redmine_www
    server localhost:3000 127.0.0.1:3000 check
The documentation says that redirect scheme can be used in the backend section. I am out of ideas.
Anything else I can try?
Mmmh, I’m not sure what why this wouldn’t work. Can you try to force “mode http” in the backend?
Thanks!!! That solved the issue!
Using mode http in the backend the “redirect” works as supposed. In fact, the variable ssl_fc is available in the backend as I can use if !{ ssl_fc}.
Thanks again for your time!
Ok, great. I suggest putting “mode http” in the default section, that will fix all front and backends.
I have one backend where I need to use mode tcp. I guess that’s the reason why I was not using mode http in the default section. I will review the docs to refresh how the mode keyword is used, defaults,…
Thanks again!.
You can just define “mode tcp” where you need it, it will overwrite the “mode http” default.
